It is currently Sat Jul 05, 2025 2:51 am
Reply to topic  [ 17 posts ]
 marshmellow/Mikuni need a lil help
Post marshmellow/Mikuni need a lil help
Im new to the site guys but i need some help. I ported and polished my intake on my PD and installed my kit and went take it for a run and the exhaust was cherry hot. so I take it that it is running to lean?? my buddy says i need to put a bigger jet in it, but where do i get it from and what size do I get?? Any advice here would be much help fellas. Im running a 2010 PD with the CDI so the carb was a bit different then the one shown in the directions that came with the kit from BPS
18x54 ProDrive boat with 36 FPR ProDrive
Mikuni, MM 2x w/baffles
Wild 'n Out!! Tear'n CHIT UP!!
Sat Apr 16, 2011 12:08 pm
Post Re: marshmellow/Mikuni need a lil help
This is where I get mine. Your carb comes standard with a 160. I would recomend getting a few like the 162.5, 165, and 167.5 Try each one until you find the one that works best.
http://www.phatperformanceparts.com/Mik ... injets.htm
I would try a local Harley shop first.
Sat Apr 16, 2011 1:02 pm
I get all mt jets right from the harley shop its only a couple bucks a jet and you dont get stuck buying like 5 of each one like in the kits they sell. Just tell them what ones ya want and for what carb. I would try the 165 or 167.5 thats what I ru in mine
Sat Apr 16, 2011 4:13 pm
Your also at a different altitude.
Sat Apr 16, 2011 6:53 pm
Had to step out for a while guys but I checked out the manual again and it says that it comes with a 175 main jet in it, so Im not to sure on what size to go with next. I guess I will just pick up a few different sizes and try that out. I will take it all off again tomorrow and research it all a bit more. Thanks for all the advice. I may have just registered to MMT today, but I've been reading and learning from the site now for about 6 months now and I found it very helpful In my decision making. Again thanks!
Sat Apr 16, 2011 7:42 pm
My BPS came with a 160. Pull your bowl and unscrew the jet and see what it is.
18x48 Charles Leonard / 36PD
Sun Jul 31, 2011 7:21 pm
all of my exhaust get cherry hot...at night they glow
Sun Jul 31, 2011 7:22 pm
Mon Aug 01, 2011 5:44 am
do a wide open throttle test. run your boat down the lake or river wide open maybe a couple miles. reach back and shut off key. make sure u are sitting down and be preparded to get maybe wet :lol: pull the plugs and they shoud be a nice chocolate brown. like some have said its not uncommon to have cherry red exhaust. but it can be a sign of a lean mixture also.
Mon Aug 01, 2011 6:08 am
since the I posted it back in april I been running a 167.5. I will run a test on it the next time I put it down tho. It seems to be doing good, but I was considering runnning a 165. I put the 167.5 because micka at mud buddy told me that would be the one since I ported and polished my intake. I just dont want to run to lean, just feel safer running a bit rich.
Mon Aug 01, 2011 7:49 am
Is your muffler still glowing red? Mine does the same but I thought it was normal.
Mon Aug 01, 2011 9:28 pm
What mods have you done to your motor?
Mon Aug 01, 2011 9:39 pm
I have a mikuni with a marshmellow and polished and ported intake. I havent noticed if it is still glowing cherry at night or not.
Tue Aug 02, 2011 5:50 am
I have had 3 different pipes on my PD, both stock and modded. They would all glow at night.
Tue Aug 02, 2011 9:52 am
I have a marshmellow/mikuni on my MB and not only does it glow like a cherry but just noticed the other nite it was shootin a flame about 8'' long that mean im running to lean also. Sry man aint tryin to steal your thread or anything but seems like you have the same prob i got.
Tue Aug 02, 2011 2:52 pm
jetting a carb is one of the simplist things u can do. and its is one of the most important things u MUST do. whats good in la. is not good in montana.inproper jetting leads to fried pistons. these carbs are sent out with a jet that in most cases will work. but you must do a w.o.t lake test with seasoned plugs. those jets are pennies of the cost of a top end job. just get out and do it. i don't think russell454 would put on a new holley carb on his hot rod with out checking his jetting and neither should we. just my $.02
Tue Aug 02, 2011 4:54 pm
Tue Aug 02, 2011 10:29 pm
Users browsing this forum: Google [Bot] and 112 guests
