It is currently Sun Dec 14, 2025 12:51 am
Reply to topic  [ 51 posts ]  Go to page Previous  1, 2
 setting Valves???...help!
Post Re: setting Valves???...help!
Tried all kinds of different timing positions, couldn't notice any real performance gains on my engine... got my "best" performance, idling, temps and speeds with no advance.
Sun Jun 07, 2009 5:38 pm
1860 Phowler Extreme W/ stage 1 36 PD
Mon Jun 08, 2009 10:53 am
Mon Jun 08, 2009 11:04 am
Mon Jun 08, 2009 11:09 am
Mon Jun 08, 2009 2:10 pm
if u got da carb from EVT dey should've sent u a short cable dat u can attach to da end of da throttle rod via the black plastic swivel thingy that ur stock rod linkage threaded into... and just use one of da existing choke cable clamps to secure it in place....
Dat setup works ok.... but a custom cable and twist grip throttle works way better.
Mon Jun 08, 2009 2:23 pm
Perdy slick! How did you run you choke cable? I don't see it in the pics?
Mon Jun 08, 2009 8:25 pm
shipped em' dis afternoon, dave!
try some breathin' exercises and maybe pinch one off to some sleezy internet porn before u go to round 2 wit da wrenches :lol:
Tue Jun 09, 2009 1:26 am
Tue Jun 09, 2009 4:54 am
Thanks everyone for the help. Got the rod from coondik today and put together. Thanks again Rod, that was a huge assist!!!
i ended up hooking the throttle up the same way PD did it except I didnt need the governor spring sh@t cause of the rev limiter(thats what silkpower told me to do, so thats what I did). Going to need a better spring than the one I have to pull the throttle back. Motor sounds real strong, I will launch and run it in the next couple of days and see what i got.
Do I need the 2 heat shields that are in the middle on the carb side of the motor?
Thanks again for the help
Dave
Mon Jun 15, 2009 9:02 pm
Dave those r more cooling than heat deflection. They direct the air towards the cooling fins on u'r heads, keep em' on. I would also look into an aftermarket oil cooler!
Mon Jun 15, 2009 9:09 pm
