It is currently Thu Jul 10, 2025 3:18 am
Reply to topic  [ 11 posts ]
 repowering 23hp gdsd
Post repowering 23hp gdsd
I want to repower my 23hp GDSD to a 35hp engine. Is the 23 hp and 35 hp frames the same? i know i will need to regear and possibly a new belt.
Sun Sep 25, 2011 6:08 pm
Post Re: repowering 23hp gdsd
No the 35 has a 36inch shaft length and the 23 a 32 inch. Other than that in may work I don't know for sure
Sun Sep 25, 2011 6:59 pm
Call gd
1850 & 36pd
Sun Sep 25, 2011 8:19 pm
Call Go Devil x 2 They will help you out with your options. Duckdon
Mon Sep 26, 2011 1:53 pm
I have the 27 hp and I wanted to up grade to the 35 and it woulda cost me $3200,
Sent from my HTC Evo
35gtr on a 1854 Deep South Custom
1436 flat pushed by a 16 GDLT
Mon Sep 26, 2011 2:23 pm
for Them to do it?
1850 & 36pd
Mon Sep 26, 2011 4:04 pm
well i sent godevil an e-mail and was told the 35 uses a different frame.
i asked for specifics and all i got was a different frame size.(Some woman named Donna)
i was thinking since i wanted more power instead of heads,cam,exhaust,etc.
i could just upsize the engine and have more reliable horsepower for the same price.
Does anyone have a model number for a briggs 35hp GDSD so i can compare some specs. and measurements?
I know i will need to replace upper gear and possibly belt. Will godevil even sell me parts that are not for my specific motor/serial number?
Mon Sep 26, 2011 4:43 pm
613477-0193-E2 is the marine without the 50 amp charging system and 613477-0194-E2 is the marine with the 50 amp charging system!!! http://www.twofeatherssmallengine.com/p ... e-50a.aspx
Mon Sep 26, 2011 4:51 pm
thanks for the info
Mon Sep 26, 2011 4:54 pm
Post Re: Re: repowering 23hp gdsd
Mon Sep 26, 2011 6:04 pm
A 23 has a 5 1/4" crank hieght.
A 35 has a 7 1/2" crank hieight.
Some mfg's 23 frames use a 35 frame with spacers under the block to bring it to 7 1/2" so they can be swaped easily.
Others are a completley different frame with a different plate hieght, considering you can't even swap a GDSD to a tall transom without buying the whole shabang lower unit and all... My guess is it is a PITA to swap them and Coco will haunt you if you do.
Mon Sep 26, 2011 6:16 pm
Users browsing this forum: No registered users and 107 guests
