It is currently Sun Apr 05, 2026 8:30 am
[ 8 posts ] |
Pressure Lubricator Question
bayouboy263
I have the Alemite Pressure Lubricator on my Long Tail. Recently it has been oozing grease from under the cap while I am running. What do ya'll think is causing this?
I currently have the "lightest" spring in the lubricator. Could this be the problem?
| Sat Dec 17, 2011 8:48 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
The seal that pushes the grease down in to the shaft housing is bad. Just replace the whole thing, no grease should be between the cap and the seal.
| Sat Dec 17, 2011 8:55 pm |
bayouboy263
 Re: Pressure Lubricator Question
Thanks.
| Sat Dec 17, 2011 9:18 pm |
Bayport
| Fri Dec 23, 2011 7:46 pm |
autogateman
There is a seal around the plunger in the lubricator.
| Fri Dec 23, 2011 9:04 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
fill the cup max 3/4 full also
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
| Fri Dec 23, 2011 9:28 pm |
kibb
^x2. If you fill it all the way to the top, when the grease in the shaft heats up it either gonna blow through the bushing seals or take a dump in the lubricator.
| Fri Dec 23, 2011 9:32 pm |
Bayport
thanks
| Sun Dec 25, 2011 8:39 am |
[ 8 posts ] |
