It is currently Sun Jul 13, 2025 11:48 am
Reply to topic  [ 15 posts ]
 starting issues
Post starting issues
36pd non cdi with a single mikuni and mm muffler
The motor is starting to be hard to start. I have to hold down the key for a long time and it will cough a couple times and shoot a mist of gas out of the carb which sometimes ignites causing a backfire.
It will start but takes a while.
Any ideas on the issue?
Thu Jan 19, 2012 9:41 pm
Post Re: starting issues
Is the starter still turning it fast enough or has it gotten slower?
Thu Jan 19, 2012 10:35 pm
It may be your coils! Sounds like what i went through. One minute it would start right up. The next i had backfire out carb and muffler and it wouldn't turn over. New set of coils and it starts first turn.
Thu Jan 19, 2012 10:38 pm
check the valves
I gave up mud motors
Thu Jan 19, 2012 10:58 pm
Thu Jan 19, 2012 10:59 pm
Sounds like a rev limiter to me.... Happened to mine when it got drenched. Disconnect it and see if it helps....
1748 prodrive 36 fpr w/ some bolt ons...
Thu Jan 19, 2012 11:02 pm
Agree on checking the valve lash, spitting back through the intake sounds like they aren't opening at the right times.
Also check battery and connections for good connection- seen them crank for minutes and not start if its not cranking just fast enough.
Fri Jan 20, 2012 1:50 am
Checked the valve lash and all seemed good...right at.005.
Rev limiter is disconnected.
Starter spins fast.
I guess I can go back one more time and check the valve lash to be 100% positive. What could cause that mist of gas to be coming out the carb?
Fri Jan 20, 2012 6:57 am
Could it be a plug wire grounding somewhere or bad coil? Sounds similar to what mine did when my plug wires were grounding out
Fri Jan 20, 2012 7:19 am
Sat Jan 21, 2012 2:51 am
Would low oil pressure have this effect. Maybe loading up cuz its not firing. Then backfiring? Idk just a thought.but I guess that may be a problem more after its warmed up?
Sat Jan 21, 2012 9:06 am
Sat Jan 21, 2012 7:13 pm
How does it run once it fires up?
Sat Jan 21, 2012 10:28 pm
It runs great once its up and running. It dies a lot at idle though.
We hauled six guys and gear all hunting season and it did great on plane.
I had this issue before but it was because the valve lash was way out. I fixed that and it ran perfect for about 6 months. I will run a leak down test but I really hope that it comes out ok.
What wire do i need to pull for the oil sensor just so I can rule it out?
Wed Feb 01, 2012 9:32 pm
If you have an oil pressure sensor, its screwed into the side of the block between oil filter and crank case. If you don't have one, there's a plug there. You just disconnect the spade connector ensuring it doesn't ground out.
Thu Feb 02, 2012 3:13 am
Users browsing this forum: Google [Bot] and 106 guests
