It is currently Sun Apr 05, 2026 5:26 pm
Reply to topic  [ 14 posts ]
 Fire problems?
Post Fire problems?
I wasnt getting fire on the #1 cylinder so i changed the coil thinking it was thatan even changed the spark plug, but still nothing. Anyone know what else could it be?
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Wed Mar 14, 2012 7:22 pm
Post Re: Fire problems?
Make sure it's not grounding out somewhere.
Have you pulled the spark plug out while in the boot, grounded it to the block and watched to see if it got spark when you crank it?
Wed Mar 14, 2012 7:32 pm
Checked diodes?
Sent by carrier pigeon.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Mar 14, 2012 7:37 pm
Yes I put the plug in the boot an checked for a spark but nothing, Now i did put hand on the plug also to make sure an i did fill a lil zap but could barely feel it.
Wed Mar 14, 2012 7:44 pm
Wed Mar 14, 2012 7:45 pm
http://en.wikipedia.org/wiki/Diode
I gave up mud motors
Wed Mar 14, 2012 8:38 pm
Where is this "diode" usually located at?!
Wed Mar 14, 2012 8:49 pm
Post Re: Re: Fire problems?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Mar 14, 2012 8:51 pm
Did the coil you get come as a complete assembly?
Thu Mar 15, 2012 6:12 am
Your plug wire is in good shape? Check continuity on the wire to Verify its not broken inside the insulation.
Thu Mar 15, 2012 7:54 am
I unplugged the diodes an still no fire on the #1 cylinder, No luck. Anything else, Maybe the magneto?
Sat Mar 17, 2012 2:59 pm
What you set the gap at? Should be .012
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Mar 17, 2012 3:27 pm
swap plug wires from one side to the other. if the problem switches sides, you've got a bad plug wire.
Sat Mar 17, 2012 5:48 pm
