It is currently Sun Jul 13, 2025 11:44 am
[ 5 posts ] |
Hobbs081828
Joined: Thu Mar 31, 2011 6:19 am Posts: 72 Location: Gilmer Tx
 is there a difference
Might be a stupid question but is there a difference in heads on vertical shaft motor vs horizontal shaft motor
Mon Mar 19, 2012 10:01 am |
Calen
 Re: is there a difference
they are the same
_________________ Calen's Engine Service 337-578-4434
Mon Mar 19, 2012 10:03 am |
Hobbs081828
thought I had a set for a 23 but they are actually off a 18 can they work on a 23 with machine work done?
Mon Mar 19, 2012 12:12 pm |
Puddle jumper
Joined: Fri Jan 20, 2012 11:56 pm Posts: 98 Location: Abita Springs, LA
Lawnmower racers use 16 hp heads on the 18 for better compression. There is a little machine work involved but it must be worth it, alot of 'em do it. Not sure wether its the same for 18 to 23. None of the engines listed share the same block but they do share parts.
Mon Mar 19, 2012 9:06 pm |
Hobbs081828
Any recommendations on who to talk to on finding out what machine work would be needed .. from the reading I did it seemed that bolt pattern will work but no luck on what would need to be done
Tue Mar 20, 2012 5:47 am |
[ 5 posts ] |
Users browsing this forum: Google [Bot] and 104 guests |
