It is currently Wed Sep 17, 2025 6:55 pm
Reply to topic  [ 19 posts ]
 methanol injection
Post methanol injection
any body played with methanol , or methanol and water, or water injection.
I talked to a buddy who has done real well with go-carts, He feels it helps the motors last longer by reducing combustion chamber temps and does produce a little more power to boot.
JD
Wed Jul 15, 2009 9:09 pm
Post Re: methanol injection
Try it out and let us know how it works. :mrgreen:
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Wed Jul 15, 2009 9:13 pm
I am the research phase now. It should not be hard to do.
JD
Wed Jul 15, 2009 9:22 pm
Wed Jul 15, 2009 9:24 pm
Profile YIM
I can do low pressure real cheap. a Harley Thunder jet, a small feed vessel with a fuel return mounted on the motor, and larger tank with low pressure fuel pump to transfer from a larger tank stored in the boat.
Kits for auto turbo market sell for 300 bucks.
JD
Wed Jul 15, 2009 9:31 pm
Used to work in a plant that had a methanol feed...
Used it for a free replacement to octane booster by mixing directly into 93 octane fuel...
A thermos full - into 5 gallons of gas (3 to 5 percent) sent the idle from 800 rpm
up to 1500 rpm on a V8 and seemed to add about 10 percent more
power across the entire powerband... It also de-carboned the engine
as evidenced by the exaust under 4 barrel drops...
If mixed excessively it will 2 phase on you and you risk pickup of
pure methanol from the tank...
Eat - Sleep - Hunt ! ! !
Wed Jul 15, 2009 9:32 pm
If you need some methonol I happen to have 2-55 gallon drums in my back yard, :mrgreen:
It was aquired in thoughts of doing this to my truck.
Thu Jul 16, 2009 6:29 am
Please remember one thing.
Thu Jul 16, 2009 6:50 am
EVT Stage 1 32PD on a 17x48PD
"I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me."
Mike Huckabee
Thu Jul 16, 2009 7:22 am
Thu Jul 16, 2009 8:19 am
why stop der?
uranium or platonium might work better :ugeek:
Thu Jul 16, 2009 8:43 am
1754 GT w/ 35 GTR Hoytafied
Thu Jul 16, 2009 8:44 am
Thu Jul 16, 2009 10:13 am
Thu Jul 16, 2009 5:34 pm
Thu Jul 16, 2009 8:11 pm
Location: In a trailer of common sense, looking out the window at a tornado of stupidity
Thu Jul 16, 2009 9:09 pm
I am not thinking about straight methanol, I am looking at a water menthanol mix to cool combustion temps. I don't need more rpm.
JD
Thu Jul 16, 2009 9:26 pm
Isn't it just windshield washer fluid? Used a lot by turbo deisels . Also used by fighter pilots alongtime ago?
Thu Jul 16, 2009 10:42 pm
Fri Jul 17, 2009 5:30 am
