It is currently Fri Jul 18, 2025 12:23 pm
Reply to topic  [ 35 posts ]
 Cam swap.....bad noise
Post Cam swap.....bad noise
I just put a BPS cam in my motor. I took the governor shaft and gear out, set valves, etc. When I crank the motor it makes a whining sound. I am unsure of where this sound is coming from. I dont believe it is coming from the cam. Could it be a bad bearing in the crankcase cover? Has anyone ever had this happen?
Thanks
1848 Prodigy
35 GTR
Mon Apr 30, 2012 10:23 am
Post Re: Cam swap.....bad noise
no body has any ideas on what this could be?
1848 Prodigy
35 GTR
Tue May 01, 2012 12:58 pm
Never experienced this issue.
Is it possible to post a vid of it?
Tue May 01, 2012 1:30 pm
Did you check for thrust ?
Calen's Engine Service
337-578-4434
Tue May 01, 2012 1:44 pm
Tue May 01, 2012 1:52 pm
Tue May 01, 2012 6:32 pm
I heard of it once when the bolt blocking off the gov gearshaft hole was a lil too long and was rubbing the gears
Tue May 01, 2012 6:35 pm
Post Re: Re: Cam swap.....bad noise
Tue May 01, 2012 6:51 pm
1848 Prodigy
35 GTR
Tue May 01, 2012 9:44 pm
You did put assembly lube on everything you could get your hands on while you were in there, right? How long has the motor run? Long enough to get a good coat of oil on everything?
Tue May 01, 2012 9:48 pm
1848 Prodigy
35 GTR
Tue May 01, 2012 10:28 pm
You installed the parts right? Why not see if you can figure it out? Pop the sump cover off and see whats up.
Wed May 02, 2012 5:46 am
Your issue is more than likely coming from outside of the engine...such as the drive itself.
Wed May 02, 2012 7:18 am
1848 Prodigy
35 GTR
Wed May 02, 2012 7:35 am
1848 Prodigy
35 GTR
Then you def. have a problem.
Wed May 02, 2012 7:55 am
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Wed May 02, 2012 8:06 am
1848 Prodigy
35 GTR
Wed May 02, 2012 8:11 am
1848 Prodigy
35 GTR
Wed May 02, 2012 8:12 am
Wed May 02, 2012 3:58 pm
1848 Prodigy
35 GTR
Wed May 02, 2012 9:07 pm
Thank you, Cody.
Wed May 02, 2012 9:14 pm
Thu May 03, 2012 5:48 am
I'll admit, I said it out loud to get the full effect
Thu May 03, 2012 6:03 am
me too!^^^ :lol:
Thu May 03, 2012 6:06 am
autogateman and other engine builders on this site. why would u stick a bolt with washers lock washers locking nuts and sealer. when all u have to do is take a pipe tap and tap it and use a pipe plug. ? a much better fix and alot safer.
Thu May 03, 2012 6:02 pm
Thu May 03, 2012 6:47 pm
Now that I typed that out, I guess you could put a cup under the hole to catch em. :lol: still, that was the reason I was given.
Thu May 03, 2012 6:48 pm
Thu May 03, 2012 8:15 pm
so when it comes out of the bottom of the gov. shaft bore due to vibration and heet. it looks good. ? :o
Thu May 03, 2012 8:23 pm
Fri May 04, 2012 6:22 am
1848 Prodigy
35 GTR
Fri May 04, 2012 9:02 am
Barroll, what's the deal? Fix it?
Tue May 08, 2012 3:43 pm
Any updates?
Wed Jul 04, 2012 9:42 pm
Thu Jul 05, 2012 12:26 pm
Users browsing this forum: Google [Bot] and 106 guests
