med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
 Smoking motor
Not a mm but a lawnmower engine nonetheless. I bought a mint john degree riding mower that had set up for a couple yrs that a buddy didn't use. Probably only used a couple seasons. Anyway when he brought it over it smoked like a mother. It resembled a dry ice machine at the local disco. Told him I couldn't buy it so he took it and got it serviced. The mower shop said likely a fuel issue due to setting up and the smoke was white. So he brought it back and it gives off just a hint of smoke at startup and goes away. If it's sets and idles tho it will do it a little then. So I used it maybe 6-8x. I checked the oil yesterday before using and it barely even hit the stick. Starts and runs great but I need to solve this issue before I burn the bastard up. It's a 15hp motor. Any help would be appreciated.
_________________ 1850 & 36pd
Wed May 09, 2012 11:41 am |
CLICKSTER
 Re: Smoking motor
my guess is its burning oil from your discription!
Wed May 09, 2012 11:52 am |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: Smoking motor
sounds like it needs a new set of rings, Charley. Did you check the oil when you acquired it and was it full?
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Wed May 09, 2012 11:57 am |
med
 Re: Smoking motor
Yeah when he took it in they flushed the fuel lines, new gas and gas line, oil change..etc. That something I could limp through summer with and keep an eye on the oil or does it need to be done pronto?
Wed May 09, 2012 12:12 pm |
MaXXis85
 Re: Smoking motor
If it is INDEED consuming oil , just check the levels each time you mow. is it a Briggs motor on it?
Wed May 09, 2012 12:15 pm |
mizzippi jb
 Re: Smoking motor
Just keep oil in it and run it. That's what most n1ggers do with their cars
Wed May 09, 2012 12:18 pm |
quack-addict
Joined: Tue Dec 08, 2009 3:24 pm Posts: 97 Location: Texas
 Re: Smoking motor
if its burning oil it probably needs a valve job.
is the smoke bluish white?
_________________ ________________________________ 1754 Excel F4 .125 w/ Black Death 4200
Wed May 09, 2012 12:42 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Re: Smoking motor
Wed May 09, 2012 2:35 pm |
deadbird8
 Re: Smoking motor
Wed May 09, 2012 8:16 pm |
med
 Re: Re: Smoking motor
Wed May 09, 2012 8:56 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
 Re: Smoking motor
That's a good sign. It means you still have oil. When it stops smoking,worry
_________________ You have your whole life to be an idiot, take a day off!
Wed May 09, 2012 8:59 pm |
chariotdriver
 Re: Smoking motor
If it sat for a while and has horizontal cylinders it could have had a little moisture in there which will leave a slight rust groove in the cylinder which the rings can't totally seal. It will run great and foul plugs a little more as long as you keep oil in it. Maybe switch to a heavier oil or start adding STP.
Thu May 10, 2012 2:17 am |
