It is currently Thu Jul 17, 2025 2:57 am
Reply to topic  [ 17 posts ]
 Converting vanny to EFI
Post Converting vanny to EFI
I've been told by some trusting fellas that you can go to a motorcycle graveyard or the store if you know what to get and get a throttle body and everything off a motorcycle and retrofit it to your vanguard like say a newer Honda shadow 750 for example cuz its just a simple v-twin itself, and boom you have a more fuel efficient, powerful and over all hell of a lot cheaper than having to buy a 1100 or 1500 dollar carb kit that still will not out perform a fuel injected engine. Or am i wrong please help and I know this will get Ni**ered up but try to stay on track.
Starting to wonder why my mother always called me special.
1750 GatorTrax HDeck 45 performance v-twin marshmellow double barrel exhaust
premium oak reverse w/minnkota cruise control
Mon May 14, 2012 6:56 pm
Post Re: Converting vanny to EFI
So you are saying a trusting fella told you this but you don't trust him?
Mon May 14, 2012 7:01 pm
not at all its just very interesting that on here i can usually get a whole lot of different advises and methods and by the end of the thread usually will learn other stuff totally off subject
Mon May 14, 2012 8:04 pm
and my buddy is not a MM type fella and guys here are MM nuts
Mon May 14, 2012 8:05 pm
id certainly do it last 4wheeler i bought was EFI and i loved it for the simple fact that while all my buddies were pulling chokes and pumping throttles when the temp dropped below 60 i turned the key, bumped the button once and waited for them to get going. also Im sure once you get into mods and all you could throw a Power Commander on it and dial er in too.. in theory that is...
Gator Trax Hybrid 1654 HuntDeck
Tue May 15, 2012 1:21 pm
It is more than just a throttle body, But It can be doable. You will need an ECM, Crank sensor, Injector(s), ignition system, MAP sensor, Oxygen sensor, and various other components. It is doable though.
Tue May 15, 2012 1:29 pm
If that welfare farmer dick would quit sword fighting with the setx girls, he could probably give some insight on what needs to be done and where to get parts. He says they have a tbi setup running on his son's gtr...
Tue May 15, 2012 1:37 pm
You would have a heck of a time with the ECM and fuel mapping, the rest of the swap would be fairly straight forward I think. I've done quite a bit of work on 2-stroke EFI snowmobile motors and it can be a mess dealing with an ECM, you will FOR SURE spend more money on that swap than you would just buying a carb kit.
Tue May 15, 2012 3:28 pm
If I'm not mistaken, tbi would be a little easier to adapt than efi and nearly as efficient. Is that correct?
Tue May 15, 2012 4:08 pm
Tue May 15, 2012 4:23 pm
my gas kubota is efi. and i didnt realize it until i bought it 2 years ago that its a kubota gas v twin.
Tue May 15, 2012 9:46 pm
I have a complete set up at the shop. Did it back in 2009. Never got around to putting it on my Generac. Runs like a bad Mofo with it. $2000 set up. We did it throttle body injection and direct port injection as well.
Wed May 16, 2012 8:39 pm
drake 1 if u don't mind me asking did u use a mega-squirt injection box. ?
Wed May 16, 2012 9:03 pm
Mega-squirt? :lol:
1850 & 36pd
Wed May 16, 2012 11:16 pm
med go to bgsoflex.com there u will find a mega-squirt.
Thu May 17, 2012 5:30 am
I heard of folks using Mega Squirt on various injection systems. Also Delphi has some sort of FI setup for Vtwins.
Thu May 17, 2012 5:46 am
1542 War Eagle with 25hp GDLT
Thu May 17, 2012 7:19 am
Users browsing this forum: Google [Bot] and 82 guests
