It is currently Sat Jul 19, 2025 8:50 am
Reply to topic  [ 4 posts ]
 Issues with battery on GTR35
Post Issues with battery on GTR35
Hey there just got a 2010 GTR35 with the commercial Vanguard. Went gigging last night and was idiling for quite some time. The spotlight got dim so we figured something was wrong and disconnected everything. Once we got back to the dock and cut off the motor it wouldn't turn over again. Guy I got the motor from says the batteries like new. Gator Tail said since it's commercial the motor won't charge the battery, unless it's around 2000rpms. Anyone have any issues like this? if so any solutions? Was thinking an Optima battery might hold a charge longer...
Fri May 11, 2012 10:50 am
Post Re: Issues with battery on GTR35
Unless it's the marine (cdi) engine, it doesn't charge the battery until around 2500-2600 rpm, so if you were just idling around with a spot light constantly running, you drained the battery. If that's the way you will normally use the boat, look into a led spotlight instead of halogen, also start bringing a spare battery with you.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri May 11, 2012 10:58 am
I had the same issue and i had to get a seperate deep cycle battery to run my Q beam, winch, and trolling motor. Now I only run my headlights and running lights on the starting battery and when i notice they are getting dim while im idling i just go for a 10 - 15 minute ride down the bayou at full speed and charge it up for a nother hour and a half or so of lights then repeat when they start getting dim again. I also started keeping some jumper cables in the boat so if i need to i can give myself a jump with the deep cycle battery.
Fri May 11, 2012 11:09 am
Thanks for the suggestions. Ended up getting an Optima for the starter battery. Now I'll have 3 batteries on board hopefully I don't kill all 3!
Fri May 18, 2012 11:44 am
Users browsing this forum: No registered users and 100 guests
