It is currently Sat Jul 19, 2025 1:33 am
Reply to topic  [ 11 posts ]
 oil on air filter
Post oil on air filter
Went to put on new exhaust the other day and noticed the left side (what i could see inside the head with exhaust removed) looked oily and the right side looked good. Looked at my air filter today and noticed oil had soaked up into the filter and looks like a vacuum line or somthing going from top of carb to the "left bank" side of the motor is were it might be coming from. Any thoughts :?:
EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Sun Jun 17, 2012 8:27 pm
Post Re: oil on air filter
That hose is the crankcase vent. If you have oil on the air filter, it's from blow by.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jun 17, 2012 8:43 pm
carry on
Sun Jun 17, 2012 8:58 pm
bad rings
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jun 17, 2012 9:45 pm
Yeah ther would be alot more oil than usual if thats the case and also the motor would be smoking if he has as much oil as he says he does, not much but there will be smoke, but on a normal basis there will be a little residual oil from the carb pulling vaccum on the crank case, i rerouted mine to my exhaust so there woulnd't be an oil in my crab area plus it evacuates better.
Sun Jun 17, 2012 9:52 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jun 17, 2012 9:56 pm
Yeah i here ya thats what i was saying on a normal basis it will be residual, well there will be a little more oil on that side because of the carb pulling vaccum on that head, without looing at it i can't really give an answer
Sun Jun 17, 2012 10:03 pm
thanks for input guys. It does smoke a little not much though. Will try to post a few pictures i took today
Mon Jun 18, 2012 4:42 am
What do the plugs look like? If the rings are bad you should see some oil on the plugs.
Tue Jun 19, 2012 4:55 am
Alright WTF? Changed spark plugs they really dint look bad, had a local Brigg's dealer adjust valve lash he said it was needing it, changed oil and filter also new air filter. Took boat out for test run and it was the best it has ever ran. The next time out ran like crap oil all over the air filter again and a loss of RPM's. I took it back to the Brigg's dealer (under warranty for 2 more years) but thought i would see if ya'll have any thoughts. Thanks
Sat Jul 07, 2012 10:12 am
Again, blow by due to bad or misaligned rings.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jul 07, 2012 10:39 am
Users browsing this forum: Majestic-12 [Bot] and 78 guests
