It is currently Mon Apr 13, 2026 3:13 am
Reply to topic  [ 23 posts ]
 Tools to keep in boat for newbie
Post Tools to keep in boat for newbie
Just put a 13 hp lt on a 1542 riveted Jon. The longtail kit is a Thailand kit. The motor is a Honda electric start. The props they gave me are aluminum. Should this scare me? I am in Ohio and i am going threw mud and lilies with no stumps. I am going to test it out on Tuesday. What are the most common problems that happen?should I bring an extra shaft? I am expecting you guys to break out your crystal ball. Any info would be great our teal season starts in a few weeks. Thanks
23 swomp/ 1542 tracker
Sun Aug 05, 2012 7:54 pm
Post Re: Tools to keep in boat for newbie
I have enought toolsin my boat to tear the engine down, pull props, prop shaft. Electrical wire, and connectors kit. Heck just bout anything you can think of put it in there cause you'll never know when it'll come in handy
Sun Aug 05, 2012 8:07 pm
^^^^x2, and don't forget a rope. I have all kinds of tools in my dry storage but it never fails that the wrench I need is never there
Sun Aug 05, 2012 8:27 pm
The problem I have up here is that in 25 years of playing in the swamp I have never seen or heard of anybody with a mud motor. It would be ackward to ask a guy that is rowing passed me for a tow :shock:
Sun Aug 05, 2012 8:36 pm
Get you a stainless prop!
Bring enough tools to work on what YOU are capable of fixing on the water.
I bring a multi-tool, tape, some electrical wire, a spare spark plug, and all the wrenches/sockets to tear the motor down to the point of anything I can repair out there. ( Throw a push rod, carb problems, ignition issues, stuff like that)
Mon Aug 06, 2012 1:38 pm
x100 on the stainless prop, i also keep my older prop and an extra prop nut in the boat just incase.
Mon Aug 06, 2012 1:47 pm
agreed on the stainless prop. and keep your aluminum prop in boat as a backup. monkey wrench, cresent wrench, small socket set, and you wouldnt believe the things you can accomplish with a multi-tool. only time i dont have my multi-tool is when i shower. :lol: but it aint far!
Mon Aug 06, 2012 2:16 pm
Bring rope small enough to splice to your pull start cord. I almost learned that the hard way but some decoy cord got me enough pull to get her started after the 30 year old pull cord snapped.
1554 GTB w/ 25GTR
Mon Aug 06, 2012 10:41 pm
Good post -
I keep a small toolset in the boat at all times - sockets/wrenches/fuses/spark plugs/cell phone with emergency contact info =)
Extra prop and prop nut are good ideas to have. I carry them as well.
Multi tools are fantastic. Get yourself a good gerber or something similair and you'll be amazed at what you can do when required.
B. MacDonald
Tue Aug 07, 2012 7:45 am
a cell phone.
also cresent wrench is the best tool ever made.
17*38 Klibert 23GDLT
Tue Aug 07, 2012 8:12 am
I have one of the 'spot' gps locator units. It's a good piece of mind to have with you. If you're not familiar with it, it's a unit that you pre program help messages into it and it uses satellites to send them if you're in an emergency.
Tue Aug 07, 2012 10:09 am
Tue Aug 07, 2012 10:20 am
JB Weld and Silicone don't leave the house with out no more.
Tue Aug 07, 2012 10:27 am
Couple of fuel clamps and a hose splice is worth millions if your fuel line cracks or get's punctured. :(
Tue Aug 07, 2012 10:31 am
ELECTRICAL CONNECTION PACK FROM HARBOR FREIGHT
SHRINK TUBE
ZIP TIES
DUCK TAPE
WIRE STRIPPERS
EXTRA PLUGS
EXTRA FUSES
ELECTRICAL TESTER
HAMMER
CHISEL
1/4" DRIVE WITH EXTENSIONS
3/8" DRIVE WITH EXTENSIONS
DEEP WELL STANDARD SOCKETS
DEEP WELL METRIC SOCKETS
6 SCREWDRIVERS
CRESENT WRENCH (METRIC!)
PROP
PROP NUT
WD-40
Tue Aug 07, 2012 11:13 am
/\ Why not just another LT kit and extra motor LOL
Tue Aug 07, 2012 11:19 am
Tue Aug 07, 2012 11:35 am
x2 on the jb weld and silicone. electrical tape, best shit out there. wouldnt hurt to bring some pussy out with ya also. never know how long you might be stranded!!!
Tue Aug 07, 2012 2:12 pm
Tue Aug 07, 2012 4:07 pm
also for a riveted jon a block of bees wax is a good idea. if you pop a rivet the wax will fill the hole and keep you going, plus when you are ready to make a real fix, it will melt right out. Thanks to Stu Alaska for that awsome tip.
Tue Aug 07, 2012 5:51 pm
I use that putty in a roll that's two colors that you break off a chunks of and mash until it' s mixed. A pinch on each side of the leak. It hardens in about ten minutes and is a permanent repair-it ain't coming off! I also have some rescue tape. Good shit. It's like electrical tape but there's no adhesive. It sticks to itself so it's not affected by water, dirt, or oil like electrical tape. They say you can fix a leaky fuel line or a broken drive belt with it, but I think that's pushing it.
X2 on the pussy
Tue Aug 07, 2012 5:58 pm
Thanks guys for all the input. I took all of your advise and I have 1 inch of freeboard. I think I need to leave the 200lb hooker on shore. I can go without the pussy as long as the birds are flying. I appreciate all the comments.
Tue Aug 07, 2012 6:02 pm
when i use to bury power, they used that black so called tape all the time. that shit is awesome! also on the jb weld epoxy/putty. get hte water stuff. i have used it to fill in dents on my hull. i have had rocks scrape over that stuff and it doesnt come off. not too shabby!!
Tue Aug 07, 2012 7:23 pm
