It is currently Sat Jul 19, 2025 8:48 am
Reply to topic  [ 10 posts ]
 Fuel line?????
Post Fuel line?????
I just picked up a 1644 that I'm putting a 25hp kohler mud buddy on. Going to run the gas tank up front after I get my deck built and bottom welded in. My question is what size fuel line would y'all suggest and would you run an electric fuel pump?
What is THAT????? Aw Hell Ground Check IT!!!!!
Fri Aug 17, 2012 7:14 pm
Post Re: Fuel line?????
I have always run 5/16 but you can probably get away with 1/4- thats not a really long run on a 16' and the stock pump should handle it. Don't add the additional complexity of a e-fuel pump if you don't have to so try it first w/o is my recommendation.
Sun Aug 19, 2012 7:03 am
I've been running 1/4 on a stock Mudbuddy 35 for 3 years with no problems. I have 24 foot of fuel line .
18x44 Gator Trax, Stage 2 Mudbuddy
Sat Aug 25, 2012 4:06 pm
X2 1/4 inch
Sat Aug 25, 2012 4:13 pm
X3 1/4
1650 ribbed abused by a Gt-35 and push pole reverse
Sat Aug 25, 2012 5:23 pm
My owners manual says 1/4", so that's what I run.
Sat Aug 25, 2012 9:06 pm
Garden hose.
Sat Aug 25, 2012 9:39 pm
Sat Aug 25, 2012 11:27 pm
Sat Aug 25, 2012 11:37 pm
I just put a custom built tank in the front of my GDLT and I went with the 5/16" from the tank to the primer ball and to the seperator, out of the seperator to my fuel filter then stock fuel pump (not e-pump), had it in for about 2 weeks and no problems.
23hp GDLT on 16x38 GD boat
When up to your nose in shit, don't open your mouth.
Sun Aug 26, 2012 12:07 am
Users browsing this forum: No registered users and 100 guests
