It is currently Sat Jul 19, 2025 9:09 am
[ 4 posts ] |
PD hydaulic reverse and trim cylinders?
mcduffws
Joined: Sat May 15, 2010 2:15 am Posts: 148 Location: Oak Ridge, La
Has anyone replaced their auto reverse or trim cylinders? Mine are rusting at the fittings, i know some of yours are doing the same. Can i only get replacements from PD, or on internet? how much do they cost?
thanks for any help
_________________ 1848 Brother Breaux 36 hp Pro Drive FPR
Fri Aug 31, 2012 5:59 pm |
Bug
Joined: Sat Oct 29, 2011 10:28 am Posts: 1068 Location: Tallahassee, Fl
 Re: PD hydaulic reverse and trim cylinders?
If they're not leakin' just wire brush the rust off and repaint affected areas. Unless u just got some $$$ to piss away...Otherwise your local hydraulic shop should be able to fix 'em.
_________________ PRODRIVE 1860 CC "Let the good times roll" Luck??? The bassards don't stand a chance!
Fri Aug 31, 2012 6:34 pm |
mcduffws
that's what I'm doing now. they aren't leaking yet, but i doubt they will make another year or two. I figured someone has a PD long enought they've had to replace them
Fri Aug 31, 2012 6:46 pm |
swampbilly
Joined: Fri Oct 07, 2011 6:08 pm Posts: 1054 Location: Dam-b, Texas
Just had my reverse cylinder replaced, it cost $295.00 at PD. not sure how much labor was tho cause I had other work done along with that.
_________________ pd36 fpr 1754 cc rig
Fri Aug 31, 2012 7:57 pm |
[ 4 posts ] |
Users browsing this forum: No registered users and 113 guests |
