It is currently Fri Jan 30, 2026 6:00 pm
Reply to topic  [ 53 posts ]  Go to page 1, 2  Next
 Pro Drive Maintenance
MMT Site Admin
Post Pro Drive Maintenance
Posted from old site to here, courtesy of Hizzoner:
I thought I would post up the Pro Drive maintenance information for anyone interested (or at least for my future reference). All of this compiled form this site and/or Briggs. Feel free to add or correct.
Oil:
Change after initial 8-10 hrs and then every 25-50 or annually.
Any quality 5W30 or 10W30 regular or synthetic (2 Quarts)
Oil Filter:
Briggs-492932S
WIX-51348
NAPA GOLD-1348
Spark Plugs:
Champion-RC14YC
NGK-ZFR5F-11
BOSCH-7527 or FR8 DC
gapped at .030
Fuel Filter:
BRIGGS-691035
WIX-33011
Fuel Line:
1/4" ID or 5/16" ID
Air Filter:
BRIGGS-692519
K&N-E-4665
Lower Unit Oil:
Change annually or every 100 hrs.
80-90 Weight Gear Oil
Grease:
Grease every 50 hrs. or annually
Marine Grade
Valve Clearance:
Check after first 50 hrs. and then every 250 hrs.
Valve clearance with valve springs installed and piston 1/4 in. past dead center (check when engine is cold)
Intake/Exhaust- 0.004 - 0.006 in.
Tony Broussard
Admin | Owner
Admin | Owner
Admin | Owner
Admin | Owner
Admin | Owner
CEO | Graphic Details Digital Media
Wed Jan 14, 2009 5:28 pm
Post Re: Pro Drive Maintenance
Note: By not useing the Factory Oil Filter you can void your warrenty.
There is a check valve in them that doesnt allow the oil to bleed down form te system when its not running.
Sun Jan 18, 2009 5:49 pm
Added: Be sure to check all engine bolts.
I lost 3 yesterday and caused a nasty oil leak. Thankfully no damage done and back on the water.
Home made boat with a 32 PD SS FPR
Sun Jan 18, 2009 9:28 pm
does anyone have this same type of information except for a godevil
Thu Jan 29, 2009 6:54 pm
Picked up a few oil filters and found that Stens makes a replacement oil filter for B &S. Found this during my search using the Briggs part number. At least the filters are still made in the USA 8-)
Stens 120-485 replaces Briggs-492932S
Wed Feb 04, 2009 5:32 pm
On the new PD lower units, what is the new silver allen head screw about halfway up the lower unit? This wasn't on the old drives. Is this another place to add LU oil?
FYI - Don't forget to grease the fittings for the FPR under the velcro'd clutch cover. Also check all the bolts/screws on the hydraulic trim unit. There is a screw on the backside of the hydraulic motor that should be checked too.
Fri Feb 20, 2009 11:59 pm
Wilson....there's a grease fitting in that plug!
"Gofer Everette?"
Fri Jul 10, 2009 7:11 am
Profile YIM WWW
I had an old manual and was emailed a new one, so I got it figured out.
Fri Jul 10, 2009 8:40 pm
Thanks
Thu Jul 23, 2009 8:04 am
To KCM;
Lost Three engine bolts yesterday on my 32 pd,got the same nasty oil leak, Did you replace the gasket?, or were you able to put new bolts in and call it good.
Mon Jul 27, 2009 12:55 pm
Wix oil filter is 57035 not 51348. Crossed it with the Briggs 492932S after seeing the 1348 was too small.
Sun Sep 20, 2009 6:20 pm
Will that K&N air filter (e-4665) work for the 36hp pro drive?
Because it looks a little smaller.
Tue Sep 22, 2009 9:57 pm
Wed Sep 30, 2009 7:49 pm
Whar is MAX rpm on the 35 HP Kohler ?
46" 42 lbs, KING Salmon
On the roads of life potholes keep things interesting
Thu Oct 01, 2009 12:16 pm
Fri Oct 16, 2009 9:21 am
lost 5 bolts & most of the oil. lucky i was at the camp when i saw it, the eng sounded like it was going to jump off the boat. i look back at the bolts real often.
Thu Jan 14, 2010 3:16 pm
Really good info. My owners manual has info on the unit, but nothing on the actual engine.
Sun Sep 19, 2010 9:16 am
Mon Sep 20, 2010 12:00 am
will these spark plugs works for a 32pd. i didn't see the specifics on what engine to spark plug. thanks
Tue Apr 19, 2011 5:27 pm
just got first surface drive.1854-36hp prodrive. is it normal after only 5 hrs having to add oil ? also baffels giving out in muffler
Mon Jul 04, 2011 5:59 am
I have been trying to read and find the appropriate procedure for breaking in a new Pro Drive. What I am trying to figure out is hard to push it for how long. The best I have found is shorter runs at less than full load for the first 5-10 hours. THere is a lot of room for interpretation on this, especially on a modded motor right out of the box.
Is there a target RPM, that is a standard comfortable range to use during the break in period? Say 3800 RPM's, max 4000 RPM's for the first 10 hours? Just curious as to what some of the guys that give a chit are doing. Thx in advance. I would imagine with the mods I am going to do, the top RPM range will be 4250 trimmed appropriately...
Sat Oct 08, 2011 9:43 am
Very good thread- thanks- i have just ordered a new PD motor and this sort of info is very valuable and this concise list V Good.
Sat Mar 24, 2012 7:50 am
Here's a rookie question... On a console steer PD or GTR will the motor kick up if
It hit something like a tiller handle will?
Wed May 23, 2012 12:19 pm
Yes, but I have no earthly idea why you decided to ask that on this thread.
Wed May 23, 2012 12:28 pm
How much play can you have on the down shaft of a pro-drive. I am sitting at 1/16-1/18 of an inch. Is this acceptable? Seems like it is taking a lot of grease.
Mon Sep 03, 2012 4:10 pm
The play is most likely in the clutch but you should be fine
Mon Sep 03, 2012 6:25 pm
you only die once; and for such a long time . . .
Sat Sep 15, 2012 10:02 am
What RPMs those engines you work on run. Ours are running between 4000 to over 5500 and more.
Sat Sep 15, 2012 11:07 am
Sat Sep 15, 2012 11:10 am
Thu Sep 27, 2012 1:22 am
What is the time/money to do the routine maintenance (oil change/greasing/air filter)??
1754 XSeries Kawi Powered PRODRIVE ...
Mon Oct 01, 2012 5:29 pm
Depends on how many hours you put on it a year.
Mon Oct 01, 2012 5:39 pm
How much money/time each time you have to do maintenance?
Mon Oct 01, 2012 6:21 pm
20-25 bucks. Maybe. Idk I always have most of the stuff I need
Mon Oct 01, 2012 6:31 pm
Sun Oct 07, 2012 9:52 pm
Tue Nov 27, 2012 8:48 am
He's talking about the case bolts on the powerhead.
Tue Nov 27, 2012 8:54 am
Ive got a 27 hp prodrive, 15 hours. bought it used. It starts up but quickly dies right after. I cleaned the carb, got new plugs and changed the oil. any tips from there?
thanks
jeff
Thu Mar 07, 2013 12:25 pm
35 GTR - 1754 Extreme
Thu Mar 07, 2013 1:20 pm
[/quote]
if it's a briggs that company prefers straight 30 weight in their engines - i work on small engines for a living - kohler and kawasaki use 10w30 briggs prefers straight 30 just a heads up - or at least thats what they tell us to use[/quote]
http://www.vanguardengines.com/service- ... tbKeyword=
1848 GTB, 36 PD w/ FPR
Thu Sep 26, 2013 11:09 am
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
