It is currently Fri Apr 03, 2026 2:21 am
Reply to topic  [ 7 posts ]
 Pluming pipe ?
Post Pluming pipe ?
So I have my SS shaft 3/4 6 ft long #10 threads on
One end and keyed on the other. But I can't find any 1in Id DOM
If I go with black pluming pipe 1 1/4 will the seals still
Work.
Wed Oct 17, 2012 3:41 pm
Post Re: Pluming pipe ?
what seals? building your own i assume? 1 1/4 black pipe has a 1 1/4 id if your seals have a 1" od the 1 1/4 will not work. also most black pipe readily available at a hardware store is not seamless i would say dom is a must. contact a local fab shop or metal supply
Wed Oct 17, 2012 6:17 pm
I have seen pic's on here of pluming pipe
Being used 1 inch Inside diameter 1 1/4 od.
Just wondering if the seals keep grease it.
Wed Oct 17, 2012 8:45 pm
http://www.onlinemetals.com/merchant.cf ... its=inches
You can get shipping cost by puting the items in your cart and entering zipcode.
Also try
http://www.speedymetals.com/c-8242-round-tube.aspx
Good luck!
Thu Oct 18, 2012 6:41 am
www.discountsteel.com has everything you need too. I've ordered a lot from them, good to work with.
Thu Oct 18, 2012 9:56 am
You could use standard black pipe but do not. There is no tolerance on straightness and it will also have an weld ridge on the ID that is a pain in ass to deal with. Spending the $ on DOM is worth it.
Thu Oct 18, 2012 11:22 am
oh bull shit thats what they used to be them built with. its 1 inch shed 40 galvanized. use the couplers to make seal housings. you cut the threads in the coupler out to accept seals. if you want to use a bearing vs a bushing then use a bell reducer .
Thu Oct 18, 2012 7:35 pm
