It is currently Thu Sep 18, 2025 3:49 pm
Reply to topic  [ 27 posts ]
 SeaFoam...good idea...bad idea??
Post SeaFoam...good idea...bad idea??
I want to add some but was advised againt it. Good call or not?
Sat Aug 08, 2009 8:29 pm
Post Re: SeaFoam...good idea...bad idea??
It's good stuff. Use it. I think everyone else will agree. Wasn't there a thread on this already?
Sat Aug 08, 2009 8:35 pm
Sun Aug 09, 2009 12:31 am
Eat - Sleep - Hunt ! ! !
Sun Aug 09, 2009 6:48 am
Sun Aug 09, 2009 5:44 pm
To add to Bayouboy's comment, make sure to change your oil and plug after you do a decarb. with the Seafoam.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Sun Aug 09, 2009 5:50 pm
Sun Aug 09, 2009 6:08 pm
STFU!
I'm sure everyone lives right next to a Chevron station with Techron! lol
If you do your home work you'll see that there's no proof that 93 octane runs any cleaner than 87. Truth of the matter is there was a law suit against Exxon for such a claim. :roll:
Sun Aug 09, 2009 6:33 pm
Sun Aug 09, 2009 6:45 pm
You know its bad when Preston gets his knickers in a knot :lol: :lol:
Giga go gargle on some coco cum and then go fork yourself with your bad azz gdsd starting with the prop and working your way up until you bottom out at the base of the handle.Once again you have proven that you suck.
Seafoam is good stuff, ignore nigafowl
Sun Aug 09, 2009 7:10 pm
Sun Aug 09, 2009 7:33 pm
sounds like some pretty good stuff... kinda like a fuel induction cleaning kit for ya car
Sun Aug 09, 2009 7:36 pm
Seafoam is great stuff...
18x48 Geaux Bateau-36PD FPR
Sun Aug 09, 2009 8:18 pm
yes seafome works
Sun Aug 09, 2009 9:33 pm
Profile YIM
i run it every other tank if i can. i find that it helps keep it running better.
just my .02
Mon Aug 10, 2009 7:24 am
Mon Aug 10, 2009 7:34 am
:lol: :lol: What a "Dumbazz".
18x48 Charles Leonard / 36PD
Mon Aug 10, 2009 7:57 am
Giga, you may win the prize for the biggest DUMB FUK ever on MMT.
As was said above, when you are stupid enough to get Preston worked up, you are stupid mother f'r.
Mon Aug 10, 2009 8:49 am
Since there are so many lovers of Seafoam here, many of you appear to work in the oil industry, and many of you are DIYers, can anyone tell me where the magic in seafoam comes from? Seafoam is like stupid expensive at $9 or $10 a can. Must be a way to mix it up a gallon at a time for 1/10th the price.
I thought it would be full of benzene and tolulene and stuff that makes your kids have 17 fingers, but Seafoam is made of: (approx) "pale oil" - 60% , Naptha = 30%, and IPA - 10%.
Is IPA a short form for Isopropyl alcohol? That's just fuel de-icer. Naptha is just "crude gas" or " white gas" or Coleman fuel. Stabil is like 95% naptha. So, what is "pale oil" and what is it used for? Is it a light oil like mineral oil without all the paraffin in it? Is it like ATF - like the "old guys" used to put in their gas back in the "old days"?
M.
Mon Aug 10, 2009 10:24 am
Sounds great! Mix it up and try it and let us know what happens! ;) :D
Mon Aug 10, 2009 11:32 am
The cost went up about 4.00+ a pint in the last year or so. Used to be 5.00+ a pint and its now about 9.00 a pt. But you can get the cost down about 3.00 a pint if you buy it buy the gallon. Think it was like 54.00 a gallon at Discount Auto. I run it every 2-3 tanks.
http://www.seafoamsales.com/motor-treatment/index.html
Scroll down to video.
Mon Aug 10, 2009 1:21 pm
cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Mon Aug 10, 2009 2:11 pm
Cain't remember exactly what product it was .. but a partner of mines says thays somethin' out thar that smells the same as sea foam but it be alot cheaper.
So ~ Mines querston is ... Poker1 .. You just pours in yore tank at a ratio and it makes it mo better ? Also .. is this stuff good on mines yardmower as well ?
Mon Aug 10, 2009 2:20 pm
As per their website. Also supposed to change the oil afterward.
As a fuel system additive, Sea Foam will clean fuel injectors, clean carbon, gum and varnish deposits, add lubricity to fuel, stabilize fuel for 2 years and control moisture.
Mon Aug 10, 2009 3:24 pm
I just dump a pint in my 12gl tank when I fill it up, at least every 3rd tank for sure. Maybe overkill but I have never had an engine run problem and it cranks right up every time. Don't know that it has enhanced performance any that I can see but as Giga so strongly pointed out its part of MY preventative maintenance process. Like I said it may be overkill cause gas don't stay in my tank long enough to go bad. It ain't cheap but as much as I spend on everything else related to my hobbies its no concern to me for peace of mind I guess.
Mon Aug 10, 2009 4:37 pm
Mon Aug 10, 2009 5:09 pm
Profile YIM
You only need to change your oil if your using it as a pre service cleaner.
Crankcase oil.
http://www.seafoamsales.com/technical-i ... index.html
Mon Aug 10, 2009 6:00 pm
