It is currently Thu Nov 12, 2026 12:14 pm
Reply to topic  [ 11 posts ]
 bildge pump
Post bildge pump
Whats up just wandering if anybody is having some of the same issues as me? I have a 500gal rule bildge and is seems absolutly useless to the crap that ends up in the back of my boat. It had a small wire screen inside of the blue cap but that was constantly plugging up so i took it out and the just started plugging up the pump with pieces of grass and small sticks and blowing fueses. I really didnt have to many good ideas on how to fix this other than make some kinda cover where only the water will come into contact with the pump and maybe that will help. It gets aggravating having to always watch to see how much water you throw over the back while froggin. I like to just stomp on it and get out of the holes. Just thought i would throw this topic out and see if anybody had any info.
just one more cast...
Mon Aug 17, 2009 2:18 pm
Post Re: bildge pump
bleach bottle and sum trot line twine :lol:
Mon Aug 17, 2009 2:20 pm
guess ill just keep using all those empty beer cans in the back. Only worried when i start using an empty half gallon whisky bottle.
Mon Aug 17, 2009 2:45 pm
Modify your transom to deflect most of da water from coming over and in da boat.
Mon Aug 17, 2009 3:16 pm
Build Your transom 12" higher on each side. This will decrease the amount of water coming into the boat.
Mon Aug 17, 2009 3:20 pm
I have an Attwood 1200 gl. I never needed it for anything other than being caught in a heavy rain. Don't get water over the transom. But even with a boat full for leaves and sticks it never clogged up when I used it.
18x48 Charles Leonard / 36PD
Mon Aug 17, 2009 3:22 pm
Mon Aug 17, 2009 3:25 pm
Mon Aug 17, 2009 3:31 pm
didnt think you were serious uncle j. if adding a lip along the transom works ill see if i can find something along those lines. Thanks
Mon Aug 17, 2009 3:44 pm
None of y'all suggestions help (except Coondik's) if you forget to put the plug in.
Mon Aug 17, 2009 3:47 pm
ill take it out while runnin just so i can gain an extra mph without the h2o in the boat
Mon Aug 17, 2009 4:15 pm
