It is currently Sun Apr 05, 2026 9:00 pm
[ 6 posts ] |
Titus3
Joined: Sun Aug 19, 2012 12:14 pm Posts: 13 Location: Huntsville,AL
 Did I over grease?
I'm new to mud motors and have just bought a GD 23hp LT. I have run the new motor about 2 hours then greased it. I thought that I applied a small amount of grease but now I have a small amount of grease coming from the Upper Bearing. Is this normal or did I screw up?
| Tue Jan 08, 2013 12:34 am |
swamprat26
 Re: Did I over grease?
Wipe it up. Read your owners manual on how much grease to use. Doubt you did any damage.
| Tue Jan 08, 2013 2:16 am |
Joe Guide
Joined: Mon Nov 02, 2009 7:58 pm Posts: 159 Location: Coastal North Carolina
Roger that...Red Sticky #2 greese works best for me.
_________________ Check out "Joe Guide hunting videos" on YOUTUBE...
| Tue Jan 08, 2013 2:43 am |
Jw261
Joined: Sat Oct 22, 2011 12:20 pm Posts: 96 Location: Lower Alabama
I have a GDLT and I grease that fitting until a little comes out all the time. I thought it was designed like that. Thats how I've been greasing similiar fittings like that for years. When you hit the other fitting with the reservior, I make sure that I don't overfill it. Seems like GD manual says NOT to fill that one until it comes out of the cup. I've also noticed that I rarely need more that a shot or two from the grease gun to get that one where I want it. I try to keep it around 3/4 full in the cup at all times.
| Tue Jan 08, 2013 7:28 am |
Titus3
Thanks for the help
| Wed Jan 09, 2013 9:36 am |
Moultrie
If the seal is installed correctly it is oriented so that grease is not locked in and will flow out.
| Wed Jan 09, 2013 9:47 am |
[ 6 posts ] |
