It is currently Fri Apr 10, 2026 9:33 am
Reply to topic  [ 10 posts ]
 Engine swap on frame
Post Engine swap on frame
I have a 16hp GDLT with a vanguard v-twin, and have access to a 21hp vanguard v-twin for $100 running. Are the motor blocks that same size, and will the 21hp slide right into my frame? Or are they different sizes and require frame modifications?
Wed Jan 09, 2013 9:46 pm
Post Re: Engine swap on frame
may need to check and make sure shafts are comparible if so you'll be fine, might need a new u-joint to bolt new motor up.
Wed Jan 09, 2013 9:58 pm
i did way back in day when i had a 18 GDLT and swapped motors to a 23HP. The cavitation plate angle changed on different hp motors. You will need to call COCO and ask him if you would need to change your he will know.
Prepare for a bunch of BS with him telling you that you wont see much change switching up
Thu Jan 10, 2013 7:13 am
As long as the shaft size is the same its a direct swap. If you have a genuine godevil frame look and see where the serial number is and right by it you should see (16-23 BS 6ft).
Thu Jan 10, 2013 8:47 am
the frames are the same but the angle at which the cav plate is welded on is not.
Thu Jan 10, 2013 8:50 am
Fri Jan 11, 2013 12:17 pm
1436 Lowe
Sun Jan 13, 2013 1:28 am
But u can somtimes compensate for that simply by bending the end of the plate up or down
Fri Jan 18, 2013 12:15 pm
I bought a 2011 model 21hp v-twn for $150 running, roughly 100hrs on it. Who do I need to talk to to figure out what angle to move my cavitation plate too. And it s a GD frame....
Mon Jan 21, 2013 9:14 pm
1436 Lowe
Tue Jan 22, 2013 12:38 am
