It is currently Wed Apr 08, 2026 8:14 pm
Reply to topic  [ 39 posts ]
 Go Devil Floor Flotation
Post Go Devil Floor Flotation
I can't believe how heavy that stuff is! I bought this boat in pretty rough shape so in doing the once over, found some ants living in certain parts of the boat and just decided to do every thing I could to clean it up. I drilled out all the rivets for the floor and pulled about 150 pounds of the stuff out! And there's still some left under the middle I have to power wash out! A little water is in the boat from a recent rain, but those things were legitimately water logged. Going to replace with the pink sheet home insulation later.
Sun Jul 07, 2013 5:43 pm
Post Re: Go Devil Floor Flotation
Just leave it out. The boat performs better without it.
17*38 Klibert 23GDLT
Sun Jul 07, 2013 6:29 pm
That stuff is like 10 years old.... The new style foam is
a much better product.... $75.00 @ GD will get you new
foam and rivets....
Eat - Sleep - Hunt ! ! !
Sun Jul 07, 2013 7:38 pm
Fuk that throw that shit away and don't put nothing in it and don't rivet the floor back in unless u want to put rivets in every month have someone weld it in for u
Sun Jul 07, 2013 8:56 pm
Try around 17 years old! It's a 96'. Does anyone know if the other foam soaks up water like that? Been debating cutting out the foam under the front deck, but I don't want to make any holes if it's worth keeping the stuff.
Sun Jul 07, 2013 9:04 pm
Shit my boat is not even a year old and 90 percent of the rivets are broke loose already as soon as they all are out I am jerking the damn foam out the floor my self
Sun Jul 07, 2013 9:19 pm
Sun Jul 07, 2013 9:21 pm
Subscribed. :D
Sun Jul 07, 2013 9:27 pm
Sun Jul 07, 2013 9:29 pm
Sun Jul 07, 2013 9:33 pm
Sun Jul 07, 2013 9:35 pm
Sun Jul 07, 2013 9:36 pm
Sun Jul 07, 2013 9:40 pm
Sun Jul 07, 2013 9:46 pm
Don't use that pink home insulation. I had that in my boat and it melted. My guess is from gas from my tank up forward. No big leaks. Just a little splashed out a few times when I forgot to close it tight on the road.
Running a Alumacraft 1442 NCS with a 25 HP Orion surface drive. Not the best, but it works.
Sun Jul 07, 2013 9:48 pm
The pink insulation will definitely melt when gas hits it, good call. I'll probably just talk with GD about new strips. And for the record, ".125" is stamped on the back of my hull. I know it's old, but it's an 1856 so that's probably why the 1/8" hull
Mon Jul 08, 2013 7:31 am
What year did they come out with the new and improved foam that does not absorb water? I purchased a GD new in 2011 and my foam in the floor is water logged. Some of the strips were heavy and some were light.
Tue Jul 09, 2013 12:20 am
Tue Jul 09, 2013 6:03 am
17x48 extreme stage 2 GTR
Tue Jul 09, 2013 6:55 am
:lol:
35 GTR - 1754 Extreme
Tue Jul 09, 2013 6:57 am
Just for laughs, call GD and ask how much for a boat without flotation.... :lol: , be sure and record it.
Gator tail
Tue Jul 09, 2013 7:07 am
Thu Jul 25, 2013 1:13 pm
I'm in the process of pulling the foam out of my 18x44 go devil. Not sure if I'm gonna replace it with nee foam or not....more than likely I will order new foam from go devil. My question is, I'm pulljng the rivets out if the front and back floor and removing the foam, but you guys think I should remove the front foam, middle foam, and the side box foam in the back? How would I get that out? Cut holes and pull it out? How much water do y'all think will be in those? Aren't they sealed???
Sent from my HTC One X using Tapatalk 2
Thu Jul 25, 2013 6:00 pm
Oh yea, and mine is a '96 model 18x44, and it is stamped .125 hull thickness
Thu Jul 25, 2013 6:31 pm
Just weigh it - new it was about 600lbs - motor is about 275lbs....
You need floor foam for sure - call GD to get exact weights and
new foam and rivets as well as other options...
Thu Jul 25, 2013 8:48 pm
Thu Jul 25, 2013 8:56 pm
I always wondered why they cant figure out why the water is getting in and prevent it. Also is it closed cell foam?
Thu Jul 25, 2013 9:05 pm
Thu Jul 25, 2013 9:54 pm
Thu Jul 25, 2013 9:59 pm
Thu Jul 25, 2013 10:48 pm
Lol how many motors u got aka?
Thu Jul 25, 2013 10:54 pm
Thu Jul 25, 2013 11:07 pm
Thu Jul 25, 2013 11:09 pm
Thu Jul 25, 2013 11:10 pm
Fri Jul 26, 2013 9:02 am
Fri Jul 26, 2013 9:03 am
