It is currently Sun Jul 06, 2025 1:06 pm
Reply to topic  [ 12 posts ]
 Gutted stocker
Post Gutted stocker
Well I got the mm blues because I've got no motor to play with so I threw my 12 hp on a longtail frame a buddy of mine built. The muffler outlets came out of the side pointing directly to the u joint. So I figured I would gut and relocate outlets. I'm hoping to get around 10 hp out of this mod. Maybe throw a mikuni on it and get another 10 hp or so out of it with that. Pretty soon I will have a 33 hp motor!! I'm shooting for around 30-35 mph out of this motor with a 12x12 prop. Y'all think it will push that prop okay??
Some may call it niqqer rigged but I call it a presidential solution.
Before
After
Sent from my beeper.
Mon Nov 04, 2013 5:24 pm
Post Re: Gutted stocker
Surely y'all didn't think I was serious???!!!
Mon Nov 04, 2013 7:09 pm
i did but that exhaust will only get you 9.4 hp. LOL and i love (presidential solution) i will steal that and use it. that is some funny stuff
Tue Nov 05, 2013 6:57 am
If you turn the pipes down you can get 9.8 HP out of it.. :lol: :lol:
Tue Nov 05, 2013 12:11 pm
Did some mods to stock carb. Sharpen up everything and grind bolts down and did a little bit. Removed governor rod to carb and rev it up till valves float. Runs good until then!!
Tue Nov 05, 2013 1:19 pm
Them wardens are gunna know sumthins up when you are runnin 20 mph with a load!
Tue Nov 05, 2013 7:56 pm
Tue Nov 05, 2013 7:58 pm
How much performance does that gutted stock actually do ? I'm a newbie to engine modes and looking for some easy reliable mods for my 12 horse
Mon Nov 11, 2013 8:48 pm
Not a whole lot but I'm sure it does a little good. Get a carb and a cam and billet connecting rod and remove governor. Might be a little money but it would be well worth it.
And if its a lct motor pull the back case off and check connecting rod. They are well known for the bolts on the caps to come loose and throw a rod.
Mon Nov 11, 2013 8:59 pm
And these will hold up over time? Ive heard a lot about these mods tearing up engines
Mon Nov 11, 2013 10:40 pm
Tue Nov 12, 2013 8:07 am
I appreciate the insight. I don't know if I'm up to the mods as repairs might be a little out of my league
Tue Nov 12, 2013 8:37 am
Users browsing this forum: No registered users and 204 guests
