It is currently Sat Jun 28, 2025 12:49 pm
Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3  Next
 New 65hp stock power head for mm's
Post Re: New 65hp stock power head for mm's
get some pics/videos up - this is getting good
Mon Apr 28, 2014 1:09 pm
I can see it now....
:lol:
Mon Apr 28, 2014 1:25 pm
SwampShark: http://youtu.be/hIIvx09LznA
17x54 Extreme W/ GTR-35L Stage 1
Mon Apr 28, 2014 1:33 pm
^^^|PAHAHAHAHA EXACTLY
Sent from my SAMSUNG-SM-N900A using Tapatalk
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Here y'all go. An image to make it interesting.
Engine Type: 2 cycle, two cylinder
Bore: 76mm
Stroke: 69mm
Displacement: 625cc
Compression: 9.5:1
HP Output: 65hp @ 6300rpm
Torque: 55ftlbs @ 6000rpm
Ignition: Dual CDI (Capacitive digital Ign.)
Carburation: Dual 34mm slide or optional electronic fuel injection
Fuel Pump: Auxiliary external pneumatic / electric pump with fuel injection
Lubrication: Fuel mixed with oil @ 50:1 or optional oil injection
Rotation: Counter clockwise, viewed from output end
Starter: 12 volt electric, recoil, or both
Alternator: 250 watt/20 amp alternator standard
Cooling: Optional fan or free air cooled
Weight: 73 lbs-free air, 79 lbs-fan cooled including electric start and exhaust. Optional gearbox adds 19 lbs.
Reduction Units:G-50 gearbox available in 2.16:l, 2.29:l, 2.59:l, 3.16:l and 3.65:l ratios
Cog belt belt drive also available.
Drive Coupling: Elastomeric dampener or optional centrifugal clutch.
Dual Carb Recoil Start $5143.00
Dual Carb Electric Start $5763.00
Dual Carb Recoil Start Gear Box $6407.00
Dual Carb Electric Start Gearbox $6960.00
Fuel Injection Option $1591.00
More horsepower and torque per pound than any other engine in its class
Recommended TBO is rated at 1000 Hrs @ 75% power
Al-Nikasil coated cylinders
Mon Apr 28, 2014 1:36 pm
BAAAADDDD!!!!
Mon Apr 28, 2014 1:38 pm
Like I said, PLENTY of options for the Horizontals, stumbled on many looking for Verticals.
Mon Apr 28, 2014 1:44 pm
The real question is what is its torque at 1500RPM's??? I don't see that gear reduction case lasting 5 minutes... :lol: :lol:
Mon Apr 28, 2014 2:07 pm
Why stop at the 65hp model? I say man up and put the 110hp on it! :)
17*38 Klibert 23GDLT
Mon Apr 28, 2014 3:29 pm
Lot of horses from a small engine. Will it hold up to the torture of digging your way out of almost dry mud holes every weekend?
18'x54"CC Hanko/ 36PD
Mon Apr 28, 2014 4:22 pm
Also if u can't get gtr to commit and they don't sale just frames it will limit ur market to guys that have blown motor or u are now talking $7k for gtr and $6k for a motor
Mon Apr 28, 2014 4:24 pm
I do not foresee a profitable business if your margin on this will be ~8% BEFORE overhead.....if this is truly "revolutionary" and you had it patented, you could have the higher hp mud motor market cornered....=make more money....sounds like alot of trouble to not make you max potential.
1848 Prodigy
35 GTR
Mon Apr 28, 2014 8:06 pm
What kind of oil would we need to use in this new motor?
Mon Apr 28, 2014 8:08 pm
Mon Apr 28, 2014 8:28 pm
[attachment=-1]uploadfromtaptalk1398740015047.jpg[/attachment] don't understand the obsession in what yall are talkin about when these already exist? Someone explain
Mon Apr 28, 2014 8:54 pm
Tue Apr 29, 2014 5:02 am
Seems like a more logical use of money rather than spending 6k of a lawnmower engine to get 15 more hp and dealing with cracked crank cases blocks ect ect. And pintail its bc its small enough to mount on a frame rather than have the back half of your boat taken up by an engine. It hangs off the back as they do now.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Tue Apr 29, 2014 7:07 am
Tue Apr 29, 2014 8:09 am
GatorHide - MB
Tue Apr 29, 2014 8:36 am
I don't think I would want that much power in a tiller handle. Yall is just crazy
Tue Apr 29, 2014 9:09 am
Tue Apr 29, 2014 9:32 am
There's lots of 60 horsepower outboard with tillers even some 90's
Tue Apr 29, 2014 9:47 am
My buddy is gettin a 22x60 built right now and is puttin a merc 115 tiller on it
Tue Apr 29, 2014 10:06 am
Tue Apr 29, 2014 10:07 am
If that is a 2 stroke motor there's no reason why it shouldn't rev to 5-6k rpm easily. Why they only turning 3k?
Sent from my beeper
Tue Apr 29, 2014 10:23 am
Tue Apr 29, 2014 10:47 am
http://www.recpower.com/3203%202%20cycle%2065hp.htm
Tue Apr 29, 2014 11:51 am
Wont let me open it
Tue Apr 29, 2014 11:59 am
Ditto
Tue Apr 29, 2014 12:37 pm
Tue Apr 29, 2014 12:38 pm
www.recpower.com
Tue Apr 29, 2014 12:39 pm
Good fucking god :shock: . Open Deans link. At 65 hp 6500 rpm, the engine consumes 6.8 gal/hr. You better have a big fuckin gas tank.
Tue Apr 29, 2014 12:42 pm
Mount that 78lb 50hp motor on a copperhead, and roll out. :lol:
Tue Apr 29, 2014 12:49 pm
Does that mean 14x12 props?
Tue Apr 29, 2014 1:53 pm
Tue Apr 29, 2014 1:54 pm
Tue Apr 29, 2014 1:59 pm
Tue Apr 29, 2014 2:27 pm
http://www.duckhuntingchat.com/forum/vi ... 16&t=75648
Wed Apr 30, 2014 11:55 am
Now this is a long tail but no one specified to just surface drives
Well, the meeting with the lawyer was heart breaking to say the least. It seems as if there is a midget in Utah who is already trying to steal my design. We have both sent off for patents. It is out of my hands now, just have to wait and see which one of us will get awarded the rights to the design. My lawyer also advised me not to release any more info about the design as to not further complicate matters.
Sat May 03, 2014 8:34 pm
Users browsing this forum: Google [Bot] and 333 guests
