It is currently Wed Jul 09, 2025 4:32 pm
Reply to topic  [ 10 posts ]
 prop removal
Post prop removal
i have a 27hp prodrive, just pulled it out to do some servicing and found the lower unit seals are leaking. i need to remove the prop so could someone tell me is the prop threaded or splind?
Thu Sep 04, 2014 2:39 pm
Post Re: prop removal
I bet threaded but what year is it?
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu Sep 04, 2014 3:37 pm
not really shur of the year, it is a older motor.
Thu Sep 04, 2014 6:18 pm
Threaded. To remove, turn counter clockwise. There is a small hole, I believe is 3/8" to 1/2" just below the clutch in the spline adapter. You will need to insert something in that hole to hold backup so that the engine wont turn over when you try to undo the prop. I use a long 3/8" socket extension, stick in into the hole, let it brace against one of the 4 tower bolts then unscrew it. I made a special tool, about 3' long with a hole in one end to help. Kinda like a cheater bar. You could do this with a 2x4 or something else. Drill a hole in one end so that the shaft passes through it. Then slide the 2x4 on, and it will fit against the prop. Turn counter clockwise and it should spin off. If its the first time taking it off and it an older model, be prepared to cus a little. When you put the new prop back on, nickel-ease the threads or anti-seize so that it will be easier to get off the next time.
Mon Sep 08, 2014 5:09 am
ok thanks gana try today!
Mon Sep 08, 2014 10:24 am
You should be able to get it done like that.
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Mon Sep 08, 2014 10:42 am
the flat bar with 3/4 hole worked great! i have to change the prop shaft seals, the seal housing is it right or left handed threads and is there anything special i need to do?
Mon Sep 22, 2014 10:13 am
where can i buy new seals?
Mon Sep 22, 2014 10:54 am
Mon Sep 22, 2014 12:57 pm
thanks for the info.
Mon Sep 22, 2014 1:29 pm
Users browsing this forum: No registered users and 26 guests
