It is currently Sun Mar 29, 2026 12:11 pm
Reply to topic  [ 6 posts ]
 16 hp gdlt
Post 16 hp gdlt
go a 16 hp ran last sat took sun morning it was 3 degrees that morning the motor wouldnt start and the pull was very tight does it sound like water in the shaft that froze time for new bushings?
Tue Feb 02, 2010 8:09 pm
Post Re: 16 hp gdlt
Were those 3 degrees Fahrenheit or Celsius? The other indications of bushing wear are movement the shaft in the bushing from side to side, high grease consumption, maybe vibration.
Wed Feb 03, 2010 9:47 am
Post Re: 16 hp gdlt
take an english class and i may be able to help ya better ;)
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Thu Feb 04, 2010 9:17 pm
Post Re: 16 hp gdlt
im a duck hunter not a english teacher
Fri Feb 05, 2010 7:22 pm
Post Re: 16 hp gdlt
Check to see how much grease it takes in the zurk.. if it pushs water out of one of the seals, then yes you at least have bad seals. but wiggle the prop side to side and see if there is any play in it. if there is any play, then you would need to replace the bearings while you doing the seals. good luck! let us know what you find. ;)
Gee
Ps- dont take it personal, some of these guys only get 1 hour of internet time a day at the loony bin. :lol:
Sat Feb 06, 2010 5:53 am
Post Re: 16 hp gdlt
thanks for the info, ill give it a shot
Sat Feb 06, 2010 7:36 am
