It is currently Fri Mar 20, 2026 1:21 am
Reply to topic  [ 14 posts ]
 What boat width
Post What boat width
I have made the decision to sell my 14/36 riveted flat bottom and 13 horsepower longtail to fund a 22 hp longtail build and a new welded flat bottom. I am torn between a weld built 14/42 f and the 14/48 f. Which hull do y'all think would be better for a longtail. I want good width for planing out, stability, and some foot room while hunting but I just don't want to go too wide. What says y'all.
Sat Feb 28, 2015 2:23 pm
Post Re: What boat width
Sat Feb 28, 2015 2:31 pm
Any reason you are not going longer? I would definitely go 48 bottom. A 1648 hull would match that 22 really well.
Sat Feb 28, 2015 7:02 pm
I like a 14 footer for a couple of reasons. The smaller the boat, the less fuel my truck burns while hauling it. Also I am a fireman and I am mostly off during the week so I usually just hunt by myself. Third, the lake I usually hunt on gets drawn down in the winter and there is absolutely no vegetation to hide in and you have to hunt from your boat and I just like to stick with the smallest profile I can get away with. Really I haven't seen any drawbacks to a 14 footer as far as I'm concerned.
Sat Feb 28, 2015 9:04 pm
I understand but you may very well see better performance out of a 1648. The 22 will be heavier and a longer boat will help offset the weight while planing. As far as towing cost I'm sure you would never notice a difference. I run a 23 on a 1648 and still have issues with the nose running high when by myself. Just my opinion. I'm sure you'll be happy with whatever you get. Have fun!
Sat Feb 28, 2015 11:58 pm
I ran my 20hp on a 1548 and always wanted to see what it would do on a 16 or 17ft 42" wide boat for the record.....
I think a 1644 would be a good spot for what you're wanting. It wouldn't be nearly as sensitive to load placement, ride better, carry load better in general and if anything faster with the same hp. I wouldn't expect to see a noticeable difference in over all weight or towing resistance. You may be what, 25lbs heavier? Depending on the boat?
-Custom pool noodle
-stage 4 water wings
Sun Mar 01, 2015 9:39 am
I see what y'all are saying but it is a little about cost too. I may move up to 15/48 for 100 dollars more but the 1648 is like 700 dollars more than the 14/48.
Sun Mar 01, 2015 10:44 am
Sun Mar 01, 2015 11:10 am
My 1548 ran well but was happy with two guys and very minimal gear. Best I ever saw was 20mph solo with only safety equipment. Most of the time it was more like 17-18mph and that was after getting the prop dialed in exactly how it needed to be. An off the shelf prop would not have gotten me there
-Custom pool noodle
Sun Mar 01, 2015 11:18 am
I see what you are saying but if I was truly into speed I would make a surface drive. I just want a boat that is going to handle and ride well and have good stability for hunting. Going 17 instead of 20 is fine by me.
Sun Mar 01, 2015 11:34 am
Oh no, don't get me wrong. I have no real complaints about that rig. It did everything I asked of it, and then some. If I were real wrapped up on speed I wouldn't be getting a heavy boat and a GoDevil SD myself. That size boat (1548) is very versatile and I enjoyed it. I just needed a bigger rig. For one or two guys, you can't beat a medium sized longtail setup.
-Custom pool noodle
Sun Mar 01, 2015 12:35 pm
viewtopic.php?t=45193
Sun Mar 01, 2015 8:18 pm
i love my 1448 with a 25hp on it. i dont think you would have any issues with it
Sun Apr 12, 2015 8:28 pm
I started with a 1436 jon w/18 hp GD LT and I was lucky not to have sunk it. We all morph bigger usually and for very good reasons- better performance and safety. I presently have a 1648 w/27 Lt and I want to go 1848...you will be fine in a 1644/1648 and I also hunt by myself a lot but you will be ready for extra hunters and you learn to construct a suitable blind for your local conditions. You can also look for used hulls and save big $.
Mon Apr 13, 2015 4:37 am
