It is currently Mon Feb 02, 2026 10:37 pm
Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
 Electric Fuel pump??
Post Electric Fuel pump??
I'm going to install the e pump I bought a while back in my 32 Prodrive
Here's my setup, two tanks up front, 5/16 line to the primer bulb, then into the fuel/water sep, then to a inline fuel filter, then to the stock 32 fuel pump, then to carb!
Where's the best place to put the e pump? Was thinking I'd take the primer bulb out and put it in its place!
And do you by pass the stock pump? Is so, how? Remember this is a 32 Prodrive and it has the mech pump that goes thru the block!
"Gofer Everette?"
Wed Sep 23, 2015 12:06 pm
Profile YIM WWW
Post Re: Electric Fuel pump??
After your primer, but before your inline filter. You can bypass the pump if you like or you can pump through it.
Wed Sep 23, 2015 3:03 pm
So should I take out the water sep??
"Gofer Everette?"
Wed Sep 23, 2015 3:33 pm
Profile YIM WWW
Wed Sep 23, 2015 3:48 pm
So yours is between the primer bulb and the fuel/water sep?
"Gofer Everette?"
Wed Sep 23, 2015 4:21 pm
Profile YIM WWW
Fuel is filtered better under pressure than under vaccum. I say Primer, Water Separator, Pump, In line filter. Just my opinion.
Thu Sep 24, 2015 6:36 am
gonna jack the thread here. What pump do you like best? The one I have has not worked properly since it was new.
http://www.gatorglide.com/
gatorheads@comcast.net
Thu Sep 24, 2015 7:08 am
Thu Sep 24, 2015 7:37 am
I'm on my second facet cube. Nice pump. Different motor, hence the second one. The other one is still working fine.
Thu Sep 24, 2015 8:49 am
I got the Mr Gasket a while back! Was running the river last weekend, mine would start to loose speed, ran ok on like 3/4 throttle, then would eventually die! Could pump the bulb, and it'd run for a while then eventually die again! Had more problems outta mine in the last couple years than ever!!!
"Gofer Everette?"
Thu Sep 24, 2015 5:01 pm
Profile YIM WWW
I bet that will fix the issue.
Fri Sep 25, 2015 5:50 am
Y'all post up some pics of how your e pumps are! And where you got em installed in your fuel lines!
"Gofer Everette?"
Sat Sep 26, 2015 11:20 am
Profile YIM WWW
Mine is 6 inches from the tank. I don't even have to squeeze the bulb.
Sat Sep 26, 2015 11:50 am
Tanks in front???
"Gofer Everette?"
Sat Sep 26, 2015 1:48 pm
Profile YIM WWW
Yep. 16ft of fuel hose after the pump.
Sat Sep 26, 2015 3:51 pm
You guys that are putting the e pump inside the boat, are you wiring it to its own switch or are you wiring it to the ignition. If you're wiring it to the ignition, what wire?
I got the mr gasket pump from oreillys and it's pretty big. Can't figure on anywhere to mount it on the motor
Wed Feb 17, 2016 6:32 pm
1854 Prodigy DPE Level 3 HDR
Wed Feb 17, 2016 6:54 pm
Wed Feb 17, 2016 7:10 pm
Non CDI. I was thinking the 35s had those solenoid too. My bad, ive got a stock carb down at the shop, i should have looked at it
Wed Feb 17, 2016 7:44 pm
I just need to find a hot wire coming off the ignition and mount this giant fuel pump on the side of the motor I guess?
Wed Feb 17, 2016 9:36 pm
Wed Feb 17, 2016 9:43 pm
Thu Feb 18, 2016 6:19 am
Try the yellow wire. It's typically a keyed accessory circuit. Worked on mine.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Thu Feb 18, 2016 6:20 am
On both my predator 670 and subaru efi
Filter than pump for me. I also use a relay going to pump from switch.that way I have the voltage I need and am not taking it away from another circuit. Also use a oil pressure switch wired in. Do that if pressure goes away pump shuts off. Wire size is very important. Especially with a long run. And cold temps.
Thu Feb 18, 2016 12:30 pm
Typically it is the Gray wire on briggs harness.
Thu Feb 18, 2016 1:21 pm
Noob here.. is something going on that you have to run a fuel pump or is it for "peace of mind?"
Thu Feb 18, 2016 3:06 pm
It was the red wire on mine.
Thu Feb 18, 2016 4:22 pm
Does the fuel pump HAVE to be 12" from the tank? I would rather mount it on the inside of the transom so I don't have to run all that wire.
Thu Feb 18, 2016 4:23 pm
Thu Feb 18, 2016 4:53 pm
Fri Feb 19, 2016 7:41 am
Fri Feb 19, 2016 8:00 am
Fri Feb 19, 2016 8:02 am
Doubt it man.
Fri Feb 19, 2016 8:06 am
When I ran that Mr Gasket pump I mounted it on the transom. Make sure you throw a spare in the boat. Those things seem to take a dump at the absolute worst time. Also, the pressed in threads will seep fuel over time. I never ran the facet pump but always wanted to try it. Sold the boat before I got around to it.
What's the outlet pressure on the stock Briggs EFI lift pump? Seems like that would be maybe a more reliable solution.
-Custom pool noodle
-stage 4 water wings
Fri Feb 19, 2016 8:51 am
Fri Feb 19, 2016 9:54 am
That's what I was thinking. Gotta be less than 5. I'd give it a try. I don't think they're real expensive either.
-Custom pool noodle
Fri Feb 19, 2016 3:31 pm
Low psi pumps for efi aren't exactly the norm. Both the Kawa and the Kohler use something in the 25ish range. So it doesn't exactly "gotta be" less than 5 lol
I only say that so you confirm before you go buy pumps.
Fri Feb 19, 2016 3:33 pm
Geeeeettt outta here boy. Nobody talking 'bout efi 'round here.
Fri Feb 19, 2016 3:39 pm
Setx was.
Fri Feb 19, 2016 3:55 pm
