It is currently Tue Mar 31, 2026 3:14 am
Reply to topic  [ 6 posts ]
 Expected speed?
Post Expected speed?
Going to buy this boat tomorrow , found it on Craigslist for 400$ with out the motor, I'm also building a 13hp longtail, what kind of speed should I expect ?
Thu Nov 19, 2015 4:34 pm
Post Re: Expected speed?
What size is it? How much do you weigh? How much does it weigh? What prop you using? How many rpms you turning? And on and on....
Too many variables, dude. Your guess is as accurate as any answers you'd get with the info you provided.
Ultimately, you're putting putting a 13hp Longtail on it. If it planes out, you should be tickled. If not, will it get you where you need to go? That's the only question that should matter
Thu Nov 19, 2015 5:13 pm
Boats 14' I am 220, not sure what size prop I'm going to use or how much the boat weighs I was just curious if the guys who have ran mud motors before had any guess on speed
Thu Nov 19, 2015 5:26 pm
Anywhere from 7mph to 17. Could get lucky and get a hair more out of it
Thu Nov 19, 2015 6:19 pm
I had a 12 on a 1442 and did about 12 with 1 person and slow as fuk with anything more that that. Build a sd for it!!
Thu Nov 19, 2015 6:54 pm
my 13 hp on a 14x42 would plane and run about 14 if I remember correctly.
It would plane a second guy but when you started adding gear it fell off fast.
Thu Nov 19, 2015 11:22 pm
