It is currently Sun Apr 12, 2026 11:12 pm
Reply to topic  [ 7 posts ]
 Honda gx270 governor spring tighten
Post Honda gx270 governor spring tighten
I have recently purchased some mods for my boat to get a little more hp. This is my first long tail and attempt to mod my engine. I do not want to remove the governor because I was some protection for the engine. I have read that I can I tighten the governor to get some extra rpm. Can someone please can explain which and how to tighten the governor spring?
Thanks
Bc23
Sat Apr 09, 2016 3:26 pm
Post Re: Honda gx270 governor spring tighten
put a tie wrap on the spring to tighten the loops, and make the spring pull harder on the gov.
Or get a stiffer spring.
Sat Apr 09, 2016 4:57 pm
Sat Apr 09, 2016 7:20 pm
Sat Apr 09, 2016 7:30 pm
That makes sense. I am look online to see if I can find a stiffer spring.
Thanks
Bc23
Sat Apr 09, 2016 8:13 pm
I already took the spring off, and made the bend a little sooner.
Make sure not to bend it to much to make it shorter, because it will cause you motor to idle higher.
Sat Apr 09, 2016 8:14 pm
Thanks for your help
Sun Apr 10, 2016 5:22 pm
