It is currently Sun Apr 12, 2026 4:15 am
Reply to topic  [ 7 posts ]
 Gatortail 37 EFI losing power on plane
Post Gatortail 37 EFI losing power on plane
Need some help guys.
Here is the link to the video:
https://youtu.be/Foq2YfEHjek
Sat Jul 16, 2016 2:57 pm
Post Re: Gatortail 37 EFI losing power on plane
That is cutting out abruptly so I'd guess there is an electrical issue or fuel pressure problem.
Sun Jul 17, 2016 8:53 am
Yes it is. Was thinking fuel pump or fuel pump relay. So far I have done the following.
Motor losing power on plane between 2800-4200 rpm. Idles fine. So far have:
1. Hooked a new tank and fuel line with new gas
2. Changed both fuel filters
3. Bypassed kill switch
4. Checked battery connection
5. Changed air filter
6. Checked fire from both coils
Sun Jul 17, 2016 10:18 am
Bring it to your nearest service center for repair under warranty.
Mon Jul 18, 2016 5:31 am
Fixed. Bad connection on positive terminal of cylinoid above starter. Wiggle the wire and it would cause the engine to lose power. Replace connector and she runs like a top. Hoyt at GT said they replace both of those cheap ass connectors when they build them out.
Tue Jul 19, 2016 3:56 pm
Good deal! Thanks for update
Tue Jul 19, 2016 4:00 pm
Go over all the connections. You're pretty fortunate that one didn't KO the ECM. Good find.
-Custom pool noodle
-stage 4 water wings
Tue Jul 19, 2016 4:01 pm
