It is currently Thu Apr 09, 2026 12:51 pm
Reply to topic  [ 30 posts ]
 Why does my crankcase cover keep cracking?!?
Post Why does my crankcase cover keep cracking?!?
I have a 2012 MB 45mag that has recently been upgraded to a 55mag. Last summer (prior to the 55mag mod) I had to replace the crankcase cover and gasket because the cover cracked and gasket broke. I replaced the cover with a new cover and ran it throughout this past season (upgraded to the 55mag right before last hunting season began). The gasket started to leak and I limped it through the season while it was leaking because it wasn't a terrible leak and I monitored the oil level regularly. I just got around to ordering my new gasket and bolt/stud kit this past week as season is quickly approaching. I pulled the motor apart last night and while I was cleaning everything up, there it was, ANOTHER FU**ING CRACK!! So, what gives? Why does this keep happening? I check torque on my bolts every so often and never get much out of them. I know you guys with build motors have better luck than this, so any input would be appreciated! I need to know what to do to get more than a season out of the case cover (you all know they aren't cheap)! Thanks in advance fellas!
1852 Phowler Extreme - Phowler Light Marsh Blind - Mud Buddy 45 mag w/ Heads, Mikuni, Q exhaust, and Hammer Prop
Sun Jul 31, 2016 7:08 pm
Post Re: Why does my crankcase cover keep cracking?!?
Because briggs
Sun Jul 31, 2016 7:10 pm
I figured that would be one response! haha but what can I do to prolong the life!?
Sun Jul 31, 2016 7:13 pm
Out of balance internals, flywheels, props, outdrives, etc will find the weak links in that case/block. Some have better luck than others, but don't be fooled that anyone has an "absolute" solution for it.
One of the biggest problems I think and have seen many times. Is a inproper install of the exhaust system. Mounting brackets putting way to much force on the cover. I have seen the brackets flex when tighting them tight. Causing broken covers. when u install ur exhaust pay attention to the brackets. I also do a three step torquing of the cover bolts. Mark ur bolts when done than u can do a visual if they back off. I have seen factory exhaust with Same problems.
Sun Jul 31, 2016 7:35 pm
The Briggs bolts are cheap and they stretch and get loose. Did any of yours loosen up? Calen has the stronger bolts and engine covers.
Fri Aug 05, 2016 4:13 am
I'm going to venture out and say rotating assembly is out of balance if this has happened a few times.
Fri Aug 05, 2016 6:13 am
If gasket and stud kit comes today, that's our week end project on a 2013 MB7000. We are putting studs in block and not using bolts to attach cover. Mb says new kit doesn't come with the larger studs any more, just the two sleeves. Said a few guys were having trouble breaking them. This motor just turned over 100 hrs when gasket started leaking. I have put 64 hrs on my motor since installing block studs and the two larger MB studs, with out leaks, but when I installed the two larger studs I used a drill press to open up cover holes, to make sure they were drilled perfectly straight. IMO I think that's why the two studs were breaking that came with the old MB kit. May have been on a bind in cover, causing added side stress on the studs. I also enlarged the holes in the exhaust bracket that those studs went thru.
Fri Aug 05, 2016 7:30 am
I just received the gasket, new bolt/stud kit from BPS (Micah), and I am waiting on my new cover to get here (should be Monday). If I remember right, the last time I did it, I used the old studs which was dumb on my part.
Are you guys saying I shouldn't have ordered the new bolt/stud kit from BPS? I want to make sure I do it right this time, but I am also on a budget... I did order a used case from a guy on eBay that came off of a motor that threw a rod. The case cover looked damn near brand new though.. I figured $90 vs. $400, I wouldn't be so upset next time it cracks...
Fri Aug 05, 2016 10:40 am
Fri Aug 05, 2016 11:03 am
Do you guys load everything up with red Loctite? Also, any liquid gasket around the gasket? I have heard yamabond or hondabond works well, but I'm not sure...
Fri Aug 05, 2016 11:36 am
Fri Aug 05, 2016 12:05 pm
My case cover came yesterday and it looks pretty much new after I cleaned the old gasket residue off and cleaned out the cover with carb cleaner. I am going to start putting everything back together tonight, but am worried about the bolts instead of the studs... Will I be ok without the full stud kit? I still have the 2 longer studs like you have, but they came with regular nuts - should I get nylocs or double nut them? Also, I haven't opened my gasket up yet in fear of contamination, but does it not come with 2 new O-rings for the oil ports? Are we supposed to use the old O-rings?
Any opinions and tips for putting it back together are appreciated guys!!!
Tue Aug 09, 2016 5:15 am
1854 Prodigy DPE Level 3 HDR
Tue Aug 09, 2016 5:26 am
Where do I get them? Are they common size that I can get from a hardware store or do I need to order from somewhere?
Tue Aug 09, 2016 5:52 am
Tue Aug 09, 2016 6:10 am
I have no idea who could machine the cam and crank gear for me. I really don't have time to send the motor away to have it done.... I have about 3 weeks before we start goose hunting and I need to get out scouting before that.. My buddy's dad owns a nice machine shop, but I wouldn't have a clue what to tell him to do...
Tue Aug 09, 2016 6:53 am
Tue Aug 09, 2016 8:44 am
Still gonna leak.
Also sounds like he has bigger problems.
Tue Aug 09, 2016 8:55 am
Tue Aug 09, 2016 9:05 am
I already answered that question.
Tue Aug 09, 2016 9:19 am
vibration
Tue Aug 09, 2016 9:21 am
But that can't be it, cb. These briggs are awesome.
And you're wrong also, maxxis.
Tue Aug 09, 2016 9:58 am
Tue Aug 09, 2016 10:21 am
Lmao
Tue Aug 09, 2016 10:49 am
CB you seen ones with case gasket eliminated leak?
Tue Aug 09, 2016 11:08 am
Lots of em.
Tue Aug 09, 2016 11:18 am
He's not just having a leak issue either, he's cracking the cases. Something is horribly out of balance.
Tue Aug 09, 2016 12:49 pm
The liquid sealer is ALOT better than the stock gasket, BUT eventually it will leak again. Typically I see the sealant as a Longer term fix. This guy needs to have his crank checked aswell as the flywheel.
Wed Aug 10, 2016 8:11 am
