It is currently Sat Apr 04, 2026 4:37 am
[ 10 posts ] |
Motostar929rr
 Over revved 35 help.
Motor-06 non CDI 35, 42hsr mikuni, and bps true duals, Governor delete. Has 74hrs on it. A few weeks ago. Apparently my rev limiter quit working because the motor wouldn't start. Unplugged green wire on rev box and she purrs like a kitten...or did.... I pulled carb and rebuilt due to bowl gasket leaking. I Just reset valve lash to .005". 5 hrs ago. Long story short, sitting in driveway, after carb reinstall, I was manually running carb linkage, and the throttle cable conduit dislodged with out the spring pressure holding it in, causing it to hang up on the end of the bps bracket ferule it normally sits in. This caused it to instantly rev to the moon. Not knowing what the heck happened, I immediately jumped to the key and shut her down. Im guessing it ran no limiter, wide open for 2.5-3 seconds. Scary! I started it back up and got a small puff of black smoke, and it was idling a little rougher than expected, not terrible but not as smooth. So I thought maybe valve lash was off due to over rev. Pulled valve inspection covers, and pushrods visibly looked ok, valves were loose, like .009" max. Reset both sides, and fired it back up. Today I'm noticing a slight squeaking when it comes to a stop after turning off ignition... And I've got a slight misfire or something may be a fuzz off on the lash?? I have included 2 vids. Am I crazy to run this thing? Or should I pull it apart and see what the heck may have happened??
Sent from my XT1585 using Tapatalk
| Wed Nov 09, 2016 3:50 pm |
cb5331
 Re: Over revved 35 help.
| Wed Nov 09, 2016 4:28 pm |
MaXXis85
The squeak is probably not related, but on the Miss or puff puff; id check the idle mixture to see if its not too lean. Richen it up 1/4 of a turn and let it catch up about 10 -20 seconds before making any more adjustments. IF nothing helps, do a leak down test and verify the intake valves are leaking.
| Thu Nov 10, 2016 6:46 am |
MALLARDSX2
Joined: Wed Jan 28, 2009 6:34 pm Posts: 978 Location: GA
That noise would drive me fukin insane... just saying.
| Thu Nov 10, 2016 6:49 am |
Motostar929rr
| Thu Nov 10, 2016 9:14 pm |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
| Thu Nov 10, 2016 10:26 pm |
MaXXis85
I'm not sure what you mean by backlash on the engine. You will have backlash in the timing gear/cam gear from one direction to the other like you are describing. The crank rides on mag bearings and has the block as its Thrust bearing. If you feel a distinct backlash, and think its rods... It's hard to say. I know a loose rod wont last long at all, Like no load it will knock and make racket and chew up the crank journal. as with any internal engine issue you cant diagnose it over the internet.
| Fri Nov 11, 2016 6:08 am |
50fps
Double check your belt tension in regards to the squeak.
| Fri Nov 11, 2016 7:52 am |
Motostar929rr
| Fri Nov 11, 2016 11:16 pm |
Motostar929rr
| Fri Nov 11, 2016 11:19 pm |
[ 10 posts ] |
