DrakeHunter
 How to convert tapered shaft to straight
Hey have subaru generator with tapered shaft that I may put on a surface drive if there is a way to convert/adapt to a straight shaft. Thanks in advance.
| Wed Nov 23, 2016 8:36 pm |
fjreinke
 Re: How to convert tapered shaft to straight
| Thu Nov 24, 2016 5:39 pm |
brycecheramie
The only thing I have seen on here, the guy pulled the shaft, and had it welded up, then cut to be a straight shaft. Seems to me like the cheapest/ easiest thing to do.
| Thu Nov 24, 2016 5:49 pm |
Will C
Yea he had a good machinists buddy
| Thu Nov 24, 2016 6:42 pm |
banded-mallard
I remember seeing an adapter that can convert a tapered to a straight. It basically slides over the shaft and is held in place with the bolt at the end of the crankshaft and uses the existing keyway.
| Mon Nov 28, 2016 6:16 am |
banded-mallard
similar to this. Just need to find your correct size.
| Mon Nov 28, 2016 6:26 am |
igotit
As stated i opted to pull my shaft and have it machined. The best option is a new crank for $6-800,but at that price i could find a similar engine used with the standard crank already in it. So 2 other options.....gamble on that cheap taper adaptor,or machine shop. Id pass on the adapter,to me it has failure written all over it. On a gokart application....id gamble with it.but for a boat i may take on a 10 mile trip into marsh.....no gambling for me. Just my opinion. viewtopic.php?f=6&t=68387
| Mon Nov 28, 2016 7:43 pm |
brycecheramie
Dat be it!! ^^
It looks damn good too
| Mon Nov 28, 2016 8:18 pm |
igotit
Thanx....best option in my opinion,machine shop woulda charged around $100 to do that job. Made a new gasket for base.
| Mon Nov 28, 2016 8:27 pm |
50fps
Machine shop rates must be pretty low in some areas. Up here that would be the first hour of labor.
| Tue Nov 29, 2016 8:20 am |
igotit
$85-100 per hour average in houma,1 hr minimum....didnt take long.
| Tue Nov 29, 2016 12:44 pm |
