It is currently Mon Sep 22, 2025 6:01 am
[ 6 posts ] |
Upper bearing removal on long tail
duck1
Have a long tall MM and need to remove the upper bearing. Got the snap ring out and now the bearing won't come out of the housing. What is the easiest way to remove this bearing.
Sent from my SM-N920V using Tapatalk
Sun Nov 27, 2016 7:56 pm |
Will C
 Re: Upper bearing removal on long tail
See those teeth marks from a pipe wrench... grab it with a pipe wrench, remove assymbley, then drive the bearing out from other side
Sun Nov 27, 2016 8:07 pm |
nuccifish06
Joined: Tue Sep 16, 2014 6:36 pm Posts: 108 Location: Sunrise, FL
Hit it from the inside with your shaft and it should pop right out.
_________________ 1438 Jon / 23hp MBLT
Mon Nov 28, 2016 6:00 am |
duck1
I did hit with the shaft and it didn't work. Which way do I turn the pipe wrench to loosen the housing? And does the whole thing come off or just the front section?
Mon Nov 28, 2016 6:43 am |
Will C
Counterclockwise looking from the top
Mon Nov 28, 2016 8:11 am |
50fps
Mon Nov 28, 2016 12:34 pm |
[ 6 posts ] |
