estadalis
 aftermarket cam search
im looking for an aftermarket cam for my 36 hp vanguard. its a 2010. i want something around 305. will the ones im finding online match up with the 2010 cam? or do i need to be looking for a slightly different part. here is the one im eyeing. http://www.dynocams.com/item/popen-305tsb/cams-305/
| Tue Apr 04, 2017 4:25 pm |
SCmudder7071
 Re: aftermarket cam search
The one in the link won't work for a big block. If you're set on that, call Dyno and tell them you want it for a big block. Or call Delta Performance and order a 305 from then.
_________________ 1754 Extreme/LAProp Stage 2 GTR
| Tue Apr 04, 2017 5:33 pm |
3rd Coast Killer
Joined: Thu Aug 27, 2009 3:17 pm Posts: 2624 Location: League City, Texas. It's where I play.
I have used .305 for sale if interested. About 100 hours.
Kool-Aid Brigade
www.southernfowler.com
| Wed Apr 05, 2017 10:31 am |
MaXXis85
| Wed Apr 05, 2017 10:52 am |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
I'll take a guess for James and say a .308!!!
| Wed Apr 05, 2017 10:56 am |
MaXXis85
| Wed Apr 05, 2017 11:06 am |
pokey79
| Wed Apr 05, 2017 11:09 am |
3rd Coast Killer
hahaha.
Just trying something different for the ole taxi.
Kool-Aid Brigade
| Wed Apr 05, 2017 11:58 am |
estadalis
,305 or .308 guys?
| Mon Apr 17, 2017 3:52 pm |
Will C
20 different 305 and 308 cams. What else is done to your motor? What heads and decking? What carb and exhaust?
| Mon Apr 17, 2017 4:33 pm |
MaXXis85
Lift which you are referring too is the least important factor on a cam search.
| Mon Apr 17, 2017 7:31 pm |
MNwingsetter
Not to ask for a lesson as I'm sure there are plenty of threads on it, but is it the duration that's the most important factor then?
_________________ "There's nothing a duck hunter hates more than another duck hunter."
| Mon Apr 17, 2017 8:21 pm |
cb5331
Centerlines
| Mon Apr 17, 2017 8:56 pm |
MaXXis85
Duration and centerlines is what matters. Your motor will not make any compression until the intake valve closes. That is when fuel and air is compressed then spark plug ignites the mixture moving the piston down BBDC the exhaust opens up then pushes the burnt mixture out. BTDC the intake will open while the exhaust is open called overlap. As the exhaust charge is leaving it then pulls in some intake charge aswell to help the induction of a new mixture. So to control overlap, you need to make adjustments of the CL's or duration or both. Its a double edged sword, that has to give somewhere to receive elsewhere. There is NO do all.
| Tue Apr 18, 2017 6:31 am |
estadalis
at the moment the motor is completely stock..thanks for the replies guys.
| Wed Apr 19, 2017 12:16 pm |
Will C
With a bone stock motor im not sure you will see any gains. If your case gasket is leaking then i understand putting a cam in while you are there as long as you intend on adding heads before too long. Heads will benefit much much more on an otherwise stock engine. Do you plan on other upgrades soon and if so what are they? I know it might sound like a pita to pick a cam. We are just trying to help get the most out of your motor
| Wed Apr 19, 2017 1:19 pm |
