It is currently Sat Jun 21, 2025 1:30 am
Reply to topic  [ 12 posts ]
 boat speed
Post boat speed
i bought a 1760 lowe roughneck boat with a godevil 35hp surface drive motor. with two guys open water i only get 15 mph no matter how deep or shallow i set the prop .any help or suggestions would be needed.
Sun May 21, 2017 2:38 pm
Post Re: boat speed
Rpms? Lots of variables but that'll get the crowd started
Sent from my SAMSUNG-SM-G891A using Tapatalk
Sun May 21, 2017 4:44 pm
Post Re: boat speed
does not matter if i get 3700 3800 or 3900 rpm still the same speed.
Sun May 21, 2017 5:00 pm
Post Re: boat speed
Where you located?
Sun May 21, 2017 5:47 pm
Post Re: boat speed
topeka,kansas
Sun May 21, 2017 7:19 pm
Post Re: boat speed
I'm going with mod v hull. Am I right?
Sun May 21, 2017 8:21 pm
Post Re: boat speed
Mon May 22, 2017 4:15 am
Post Re: boat speed
Check prop size and wear. You should be running better than that regardless of hull unless its hooked to shit. I would say low 20's with a stock motor light load. If you are only turning 3800 rpms you are leaving a lot of rpms in the motor yet. Should be able to turn that stock motor/carb to 4100-4200. Are you getting a rooster tail when you are running?
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon May 22, 2017 4:28 am
Post Re: boat speed
Thu May 25, 2017 8:33 am
Post Re: boat speed
Can you tell us a little more about the motor? New/used, hours, mods, condition, etc. Any odd noises, does it sound like it is bogging out? Are you getting on a plane @ 15. Also not trying to be a dick but want to make sure you are trimming it up high enough to run like a mud motor should - with the prop about half way out of the water (not completely submerged like an outboard). Are you getting a 'rooster tail' at 15?
2016 Prodrive X 1848 37efi
Thu May 25, 2017 8:39 am
Post Re: boat speed
Is your prop wrong? Do you have a tall transom motor on a short transom hull? Not the best hull for a surface drive but you should be seeing better speeds
40HP Gatortail
Thu May 25, 2017 4:12 pm
Post Re: boat speed
Thu May 25, 2017 7:10 pm
Users browsing this forum: No registered users and 351 guests
