It is currently Sat Nov 15, 2025 10:52 am
Reply to topic  [ 7 posts ]
 GDSD 35 - Manual Trim Knob SPINS OFF - HELP
Post GDSD 35 - Manual Trim Knob SPINS OFF - HELP
Any help would be greatly appreciated. I have a 2011 35hp GDSD that I've ran on a weldbilt for five years. I just got a go-devil hull so I need to adjust the manual trim knob due to the difference in transom angles. When I turned the manual trim knob counter-clockwise to raise the trim, the knob itself unthreaded right off of the threaded shaft. I thought I could use a crescent wrench and just turn the nut that is holding the spring on....but that just loosens the spring and nut but doesn't turn the threaded bolt. I called coco and he told me to put a wrench on the trim knob and one on the nut while simultaneously turning each wrench in opposite directions to "marry" the knob to the nut. It DOES marry them, but will NOT allow me to turn to trim up.
Any advice?
Thanks,
Casey
2011 35 GDSD pushing 1844 Go-Devil Hull
Sun Jun 11, 2017 8:10 pm
Post Re: GDSD 35 - Manual Trim Knob SPINS OFF - HELP
Use some penetrating oil where the trim bolt goes in. Spray it between the frame part and the spring then where the bolt comes out the back side. May even have to put some heat to it. Sounds like it's locked up from rust. Once it's free use a little anti seize and that should keep it from happening again.
Sun Jun 11, 2017 9:17 pm
I thought counter clockwise dropped the trim?
Mon Jun 12, 2017 10:29 am
Yeah that's how mine is, counter to lower. I put some blue loctite on the knob when I changed out the trim bolt. No issues.
Mon Jun 12, 2017 12:05 pm
Mon Jun 12, 2017 7:40 pm
You need to turn it counter clockwise looking at the stern of the boat to get it out. As a rule, I always wipe off excess grease every time I grease the pivot points on the frame and wipe it in those threads. Mine are still smooth as butter. My maintainance schedule is a little more intensive than most though.
-Custom pool noodle
-stage 4 water wings
Mon Jun 12, 2017 9:47 pm
Tue Jun 13, 2017 6:39 am
