It is currently Sat Aug 29, 2026 11:03 pm
Reply to topic  [ 12 posts ]
 Gun Shy Problems
Post Gun Shy Problems
I'm looking for some input on getting my dog to not "shut down" when shots are fired. He's a wirehaired pointing griffon and loves to fetch. He's been FF'd and does line work along with some pattern blind stuff here recently. Lately, I've worked (not consistently) with a popper in the house.
I understand that I made the mistake of taking him out too early. This could have been avoided but I got excited about finally having a retriever.
That being said, what kind of regiment should I look at as far as conditioning him to sound. The option that seems most ideal would be to get some live birds and clip the feathers. Then let him go crazy while shooting the gun at a fair distance, getting closer until I see him flench.
Has anyone ever had this problem that they've fixed?
For the record, we did a Navhda natural abilities test where they deemed him gun sensitive. When he's fired up about birds he comes back to me and checks me until he remembers theres birds to be found. I just don't know how to transition this to water as we will mostly be waterfowl hunting.
Any input will be appreciated.
Gatortail Extreme 1854 w/ GTR 37 efi or 90hp Yamaha
Godevil 1860 w/ gd 35 sd with a Mikuni Carb Sold
Wed Aug 09, 2017 6:58 pm
Post Re: Gun Shy Problems
Gun shyness is man made. It's VERY hard to ever fully fix, but clipped winged pigeons and a gun far away is where I would start. If anything can fix it, live birds can.
Wed Aug 09, 2017 7:13 pm
I've seen it recommended to start with a 22 or other small caliber gun far away...someone shooting while you're playing and retrieving. Then very slowly the shooter comes closer. The more you can associate the noise with fun and retrieving the better. As he gets used to that the shooter can use larger guns and repeat the procedure.
If another person is not available and you have an outdoor shooting range nearby you could park up the road and walk closer and closer instead.
2016 Prodrive X 1848 37efi
Thu Aug 10, 2017 6:42 am
You don't want to try the gun range thing. You want to build an association that a gun shot means a bird to pick up. It builds excitement and a positive association rather than acceptance.
Some use 22's but if you start someone 300 yards out and progressively work it, you will be just fine avoiding an extra step and just start with a 12 gauge
Thu Aug 10, 2017 7:29 am
I've heard that a gun range would be a bad idea. I don't think it would give me enough control if it starts to go wrong.
I have a starter pistol that I plan to use. Just need to find a place to use it.
Thu Aug 10, 2017 10:26 am
Personally I would avoid skipping steps to save time considering this is either going to make or break whether you can ever hunt with your dog. Sure you can associate gun shots with retrieving something...but I would rather worry about forming that association later on. The biggest priority to me is getting them used to gunfire and not care about it.
Thu Aug 10, 2017 3:46 pm
Bacon bits work really well initially. Get them playing, start at distance with a 22 short, give bacon bits when they don't pin their ears on the shot
#TheGhostBoat
Thu Aug 10, 2017 4:35 pm
Seen this a little late, but if you have a local trap club take the dog there and sit off in the distance.
Overtime (days to weeks) work in closer, the dog will let you know how close to get as it gets use to it.
I did this with a friends dog who would run to the next county when you pulled a gun out of the case and in the end it all worked out.
Fri Sep 29, 2017 6:45 pm
Quote:
Sat Sep 30, 2017 7:09 am
I started my chocolate lab at a young age with loud noises around the house. For example, cutting the grass around her kennel, using the vacuum, turning on loud music, etc. I found that that helped in getting her use to loud noises prior to introducing the gun. Prior to introducing the gun, I did the typical "fetch" routine for a couple of months and incorporated an assortment of duck calls that i would blow prior to having her fetch the treat. when i introduced the gun to her (about 4 months old), i would make her sit next to me, fire a 20 gauge shell, and then give her her favorite treat and praise her. after doing that a couple of days, she associated the gun with something positive (the treat) and knew that it was something good. it didn't take long for me to introduce the gunfire with the retrieval regiment for her to be comfortable. Once she was good at that stage, i would take her to shoot clays and such and she has no issues with gunfire during hunting or training.
Best of luck to you. Every lab can be a good hunting dog, its just that some get it together faster than others. I find teaching them yourself helps you bond with your dog more and makes hunts more enjoyable.
Sat Sep 30, 2017 9:10 pm
I ended up getting with the trainer. He said he's fixed this before so I trusted him. He did a tower hunt with the trainer this past weekend. From what he said, he's seeing a lot of improvement. We will find out Saturday how much improvement.
Wed Nov 08, 2017 7:39 am
Wed Nov 08, 2017 9:44 am
