It is currently Fri Mar 27, 2026 6:34 am
Reply to topic  [ 4 posts ]
 23hp Briggs won’t run with load added to it
Post 23hp Briggs won’t run with load added to it
Need help. Mud buddy 23 runs great out of the water, but as soon as I dip the prop in the water it only idles then eventually sputters and dies. I have replaced the carb, spark plugs, checked all of the wire connections, And about everything j know to do. I thought the rev limiter might have been the problem, but I took it off, and same outcome. I got the rev limiter wet at one point and I figured that was the problem. Just wondering if maybe I shorted out the circuit breaker or something. Just need some help. Thanks!!
Wed Feb 14, 2018 4:54 pm
Post Re: 23hp Briggs won’t run with load added to it
I can go ahead and tell you what everyone’s gona say.
Check your compression and do a leak down test and go from there.
Wed Feb 14, 2018 7:00 pm
That sounds like it's a fuel problem.
#TheGhostBoat
Wed Feb 14, 2018 7:04 pm
Just checked and figured out I’m only running on one cylinder
Wed Feb 14, 2018 7:22 pm
