It is currently Mon Mar 23, 2026 11:28 am
[ 5 posts ] |
50fps
 Briggs piston pin fit?
Quick question, but are the pins pressed or floating in the rod end?
Been awhile since I tore one down and cannot recall.
| Sun Jun 03, 2018 10:17 am |
Russ
 Re: Briggs piston pin fit?
It's a pretty snug fit, but doesn't need a press.
| Sun Jun 03, 2018 10:19 am |
MaXXis85
in all honest it is too FUCKING tight lol. Most all motors I take apart the bottom of the piston is discolored at the piston pin from lack of clearance... It is splash lubed..
| Mon Jun 04, 2018 1:51 pm |
50fps
| Mon Jun 04, 2018 5:51 pm |
MaXXis85
yep. inconsistency. They should free float in both the piston and the rod.. I usually see more of the piston being too light and it rotates on the rod only. A lot of times I see it on motors than some joe bubba has take apart and has beaten the piston pin with a punch "mushrooming" the ends causing issues too... so. There isn't enough clearance IMO to start with stock though.
| Wed Jun 06, 2018 5:19 am |
[ 5 posts ] |
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest |
