It is currently Mon Aug 31, 2026 9:12 pm
Reply to topic  [ 4 posts ]
 20hp Honda bogs down under load.
Post 20hp Honda bogs down under load.
I have Gx620 on go devel frame. Motor runs good idles good when prop is out the water. Bogs down when I put in water. New carb, fuel pump, fuel filter, new hose. Looks to be getting food fire from both spark plugs. What all think?
Sat Oct 20, 2018 9:49 am
Post Re: 20hp Honda bogs down under load.
Is it over propped?
I had a 25 Kohler, a stop nut came loose somewhere and when I went to give it full throttle it would activate the choke and bog it down.
Fri Oct 26, 2018 8:38 pm
Check the oil. Those things don't like too much oil. Other than that, likely culprit is simple, and carb related.
#TheGhostBoat
Mon Oct 29, 2018 9:10 pm
Try to keep the bulb primed by hand every few seconds to see if that helps. I replaced the fuel pump, carb, and filter on my gx clone but it starve itself out of fuel after idling for a minute or under load. I put a low pressure electric fuel pump on, that solved my issue
Sent from my SM-G950U using Tapatalk
Extreme Metal Fab 16x48 w/huntdeck
40EFI Backwater LT
Tue Oct 30, 2018 4:12 am
