It is currently Sat Nov 15, 2025 4:32 am
Reply to topic  [ 5 posts ]
 3/4 hex prop conversion
Post 3/4 hex prop conversion
What’s your guys thoughts on this? Would it be possible to take a 3/4 hex shaft prop and thread it to 3/4? I’m guessing this won’t work but I figured I’d ask y’all. Maybe somebody has tried it.
Mon May 27, 2019 11:32 am
Post Re: 3/4 hex prop conversion
We saw a big blade once that was part hex, part threads. Not sure of your reasoning for doing it, but it wouldn't be that hard if you had a halfway functional machinist floating around. Getting a new prop would probably be cheaper.
#GhostBoat
Mon May 27, 2019 11:44 am
I haven’t been able to find a big blade style prop in 3/4 threaded. Stock prop is undersized afternoon performance mods have been added. I’ve got throttle for days but I just don’t have enough prop now.
Mon May 27, 2019 12:44 pm
More pitch and cup would probably be your fix if you have rpms for days
Mon May 27, 2019 3:27 pm
I had a threaded Big Blade prop converted to a 3/4" hex shaft size. I would assume a machine shop could go the other way. I also had a machine shop make me replacement shafts both threaded and Hex. Surface drives and long tails with replacement bushings.
Thu Jun 06, 2019 4:54 pm
