It is currently Mon Mar 23, 2026 2:47 pm
Reply to topic  [ 20 posts ]
 Gator Trax hull pitting
Post Gator Trax hull pitting
2011 Gator Trax Marsh Series 1750 w/ hunt deck. Found pitting all over on bottom of the hull, one area leaking. Freshwater use only, no onboard charging system besides a system made by original owner that allows battery to charge off towing vehicle. Treated trailer bunks with heavy duty plastic covers in excellent condition. I’m second owner and bought boat 2 months ago. I know the first owner well and he took immaculate care of this boat, thus, I never inspected the hull when I purchased; my mistake.
The boat was gently used in my opinion by 1st owner. Heck, the 2011 black death had 34 hours on it when I purchased. The boat was kept in heated storage its entire life. I am having a hard time understanding how a hull from a company I’ve heard so much about can have this pitting issue after 8 years of gentle freshwater use. Cheap overseas aluminum? WTF!
Any one familiar with this? Input please and thanks. If this has been discussed somewhere else please help me out, I searched and didn’t find much.
Sat Dec 07, 2019 10:24 pm
Post Re: Gator Trax hull pitting
call them, they have a lifetime warranty on their hulls. Atleast see what they will do
Sent from my SM-G973U using Tapatalk
Mon Dec 09, 2019 6:01 am
[quote="DmaxHunter"]call them, they have a lifetime warranty on their hulls. Atleast see what they will do
That had been done already. Was told warranty for marsh series hull is 1 year for the 1st owner. They suggested gator glide.
Looks like this will be my first and last Gator Trax.
Mon Dec 09, 2019 6:12 am
Gator trax suggested gator glide to fix pitting and a leak on a hull they built? Wow. Times must be hard down there.
#GhostBoat
Mon Dec 09, 2019 6:42 am
Could be on-board electrolysis from the charging system. Boat needs to be properly grounded. Is the pitting where it sets on the bunks or all over?
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Dec 09, 2019 9:06 am
If you're going to use the GatorGlide to insulate the bottom of the boat you need to treat it first. I would sand it down best you can and then maybe use a wire wheel. "A stainless wire wheel "you do not want to use a carbide wire wheel you'll create a battery on the bottom of your boat. clean the pits out the best you can and then use vinegar and water solution about 30 to 40% vinegar and the rest water, that will eat some of that corrosion out of the pits that you can't reach with the wheel. I would wash it a couple of times and then clean it good soap and water, let it dry then wipe with acetone. Then I would use the gatorbase and then G2.
I don't like the plastic bunk covers or pressure-treated against aluminum that also causes pitting and the plastic bunk covers create a lot of wear. I just put down to Spruce 2 by 8 on my air boat trailer after 8 years with gatorglide on the old bunks. call me anytime
Mon Dec 09, 2019 9:19 am
Mon Dec 09, 2019 9:46 am
Mon Dec 09, 2019 9:52 am
Mon Dec 09, 2019 10:40 am
Mon Dec 09, 2019 11:17 am
Mon Dec 09, 2019 2:11 pm
So if my google’ing is correct, installing a sacrificial anode made of magnesium should help. If this is true, anyone know how to determine how big and where the anode should be installed on a GT hull?
Pitfalls of installing an anode? Does it work? Who has em’?
Mon Dec 09, 2019 9:26 pm
I would solve the underlying issue before adding that. Pitting happens, but it's a rare thing in a freshwater only boat, so something's going on worth figuring out. Then you can add the anode for peace of mind.
#GhostBoat
Mon Dec 09, 2019 10:10 pm
Tue Dec 17, 2019 4:15 pm
Battery hooked to motor, black to negative, red to positive. Dont ground shit to the boat. At all.
#GhostBoat
Tue Dec 17, 2019 7:01 pm
Yep, electrolysis don't ground to the boat, fresh water, salt water , bunks, none of that matters. Don't transfer through the hull itself.
Tue Dec 17, 2019 7:16 pm
BUT, your motor bolts to the boat. which the motor is grounded.... HMMM
Wed Dec 18, 2019 9:32 am
Wed Dec 18, 2019 2:46 pm
Thu Dec 19, 2019 6:33 am
I used the wrong term, not electrolysis, electrolytic corrosion is what I was thinking. "Stray current" passing through the hull. Could be a chaffed wire somewhere or bad ground or neutral allowing the hull absorb and transfer voltage.
Sent from my Pixel 2 using Tapatalk
Thu Dec 19, 2019 6:43 am
