It is currently Wed May 20, 2026 5:47 pm
Reply to topic  [ 9 posts ]
 Thinking my prop is burnt
Post Thinking my prop is burnt
All of a sudden my motor isn’t getting the RPM’s it was? My prop does look a little warn but not terrible. Could this be the issue or could there be another issue? I’m running a 17 X 54 Pro-Drive boat with a 40 HP. What y’all think??
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Thu Jan 09, 2020 6:22 pm
Post Re: Thinking my prop is burnt
Are you getting more or less RPMs? More wear should mean increased RPMs.
Thu Jan 09, 2020 6:36 pm
All of a sudden as in on same trip or "last time was fine, this time not" and what the difference in rpm and speed? Could be many things but need more information.
Sent from my Pixel 2 using Tapatalk
Fri Jan 10, 2020 6:09 am
Getting less RPM and less speed. The only reason I say it’s something with the prop is it looks like it’s worn down pretty good. But the lower RPM’s is what throwing me off.
Fri Jan 10, 2020 6:17 am
Less prop equals more rpm’s
Sounds to me like leaking valves
How many hours on the motor?
Fri Jan 10, 2020 8:41 am
Right at 50 hours.
Fri Jan 10, 2020 9:03 am
Yep, my bet the valves are leaking, typically a Prodrive prop picks up a tad more speed with a little wear and then starts to fall off. But with any prop, the more wear, the more rpm because you have less grip.
Fri Jan 10, 2020 5:14 pm
Definitely not the prop this morning on the way back from the duck lease I could barely get the motor to run more the idle speed and it was running terrible. So it’s going to the Prodrive shop tomorrow.
Sun Jan 12, 2020 6:32 pm
Will is right. It’s not your prop bud
Sun Jan 12, 2020 7:01 pm
