NESTLES197
Joined: Tue Jul 26, 2011 3:11 pm Posts: 30 Location: Cecilia, LA
 Not the right equipment for this situation
| Wed Aug 31, 2011 10:09 am |
WestEndAngler
MMT Moderator
 Re: Not the right equipment for this situation
That truck needs about 4" more lift & 38's under it... Lockers F&R would have helped. Whose winching that?
| Wed Aug 31, 2011 10:15 am |
NESTLES197
no winching, had a friend pull me oout. yea i wish i could put a bigger lift/tires on it. don't need lockers all 4 pull for now. wanting to put a small block in it first
| Wed Aug 31, 2011 10:24 am |
WestEndAngler
MMT Moderator
| Wed Aug 31, 2011 10:28 am |
NESTLES197
Not on this lil chit, when in 4x4 it's 4x4. don't ask why it just is. never seen it 3wd
| Wed Aug 31, 2011 11:33 am |
MaXXis85
Flex it in a ditch I bet the first wheel to come off the ground will spin and the one touching will not. Lockers pull ALL THE TIME.
Ill play... Toyota on 38's
| Wed Aug 31, 2011 12:15 pm |
WestEndAngler
MMT Moderator
22RE? or did you get the 3.0L?
| Wed Aug 31, 2011 12:18 pm |
MaXXis85
3.slow =( its on the way out. Used to be able to turn the 38's well with the 5.29 gears, But since I added the Dual transfer cases the parasitic loss and 213k miles is catching up with it. It lacks the Horsepower.
| Wed Aug 31, 2011 12:19 pm |
keestan31
Joined: Fri Aug 21, 2009 9:40 am Posts: 1703 Location: Groves, Texas
| Wed Aug 31, 2011 12:48 pm |
WestEndAngler
MMT Moderator
305/327 or 350 all are fairly straight forward swaps. Is your pumpkin on the front axle a passenger side drop? Atlas T.C.?
Small Block for sure your are limited in space with most Toys
| Wed Aug 31, 2011 12:50 pm |
NESTLES197
I've passed in some ditches and never had it free wheel. thought I was fuked, ditch was a lil soft. don't lnow what it is about my lil black, just wish I could afford to do more to it (performance) wise that is. fuking lift kits are expensive, was looking for a front straight axle conversion kit.
| Wed Aug 31, 2011 1:01 pm |
WestEndAngler
MMT Moderator
You may have a positrac or limited slip in that diff.
| Wed Aug 31, 2011 1:10 pm |
NESTLES197
I've been working at a chevy dealer for almost 22 yrs, I know a lil about it. when I replaced the gears the front was open (no locker) the rear has a posi unit. I have pulled on several things, got stuck twice. Second time is the picture (tires where bald) hit a big hole past my knees & centered the truck, towing a boat did not help either. but anyways which it had more that the 4.3 V6 it has now. but that's another story, wanting a mm rig now with no $$$$$$$
| Wed Aug 31, 2011 1:32 pm |
WestEndAngler
MMT Moderator
I would have saved a sh!t load of money by purchasing a MM rig back in the day rather than trying to mud my Toy. Let's see...
4" Lift, 33" Tires, Detroit Locker, custom front bumper, winch mounts, 4.88 gears, crawl kit, extended travel kit, removed sway bar since it was no longer a grocery getter... commenced to blow the engine, twice! Rebuilt it and bored it over .040 or is it .004 forget which lol...
Anyways it was a beast. Bought it for $10K sold it for $12500
| Wed Aug 31, 2011 1:44 pm |
MaXXis85
When I get the want to mechanic on it again it will put some sort of GM LS engine, 4l60e or 4l80e trans, and a Np241 passenger side with VSS. I have a passenger drop axle, But once i upgrade to aV8 I will get away with toyota axles for a while, then I will want 1 Ton axles!
| Wed Aug 31, 2011 1:48 pm |
NESTLES197
Now that's what I'm talking about & from what I have read in here sooping up a MM is not dat CHEAP either
| Wed Aug 31, 2011 2:02 pm |
keestan31
MaXXis85
| Wed Aug 31, 2011 2:09 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
^^ I had 6.0. I bored 30 over put H beam rods valve release pistons heads cam rockers intake long tube headers 175 nitrous and a dyno tune all in a extended cab 02 chevy 1500 and it blew more 4l60e than I knew what to do with
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
| Wed Aug 31, 2011 4:50 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
| Wed Aug 31, 2011 8:20 pm |
OwenDickeson
 Re: Re: Not the right equipment for this situation
| Wed Aug 31, 2011 8:32 pm |
take'emgator
I tell you what you sure are quick to call someone out but when its you you get all butt hurt and cry like a lil bit*h, go play with your toys and little the grown ups talk.....Now i see why you have the word DICK in your name you little cock sucker
| Wed Aug 31, 2011 8:35 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
I wanna play
_________________ I gave up mud motors
| Wed Aug 31, 2011 8:38 pm |
take'emgator
| Wed Aug 31, 2011 8:40 pm |
OwenDickeson
your too easy.
| Wed Aug 31, 2011 9:04 pm |
