https://mudmotortalk.com/mmt_v2/
What kind of hours does everyone have on their MM??
https://mudmotortalk.com/mmt_v2/viewtopic.php?f=17&t=32630
Page 1 of 2
Author:  STR8limits [ Sun Sep 23, 2012 9:25 pm ]
Post subject:  What kind of hours does everyone have on their MM??
08 35 GDSD with 221 hrs no problems at all
Author:  CootSlayerRMFT [ Sun Sep 23, 2012 9:28 pm ]
Post subject:  Re: What kind of hours does everyone have on their MM??
Why did you randomly select the Mud Motor Photos forum to ask this question that has already been asked fifty-eleven times? I think dguidry has all the info you're looking for in a link to a recent poll in his signature...
'07 35 GDSD with about 400 hours. Broke the u-joint assembly in the lower at about 360 hours, but no complaints overall.
Author:  STR8limits [ Sun Sep 23, 2012 9:34 pm ]
Cuz I'm cool like that
Author:  mississippiduckboy [ Mon Sep 24, 2012 3:32 am ]
1997 Go devil 20 H.P. long tail with 750+ hours on the first tech, and around 500+ hours on this tech...no telling what was on it before I bought it. And yes things have broke and I have had to fix just about everything at least once.
Author:  CJB [ Mon Sep 24, 2012 6:06 am ]
viewtopic.php?p=326321#p326321
Author:  eljefe [ Mon Sep 24, 2012 8:51 am ]
09 with 330 hours on it.......needs a new starter.
Author:  greg f [ Mon Sep 24, 2012 11:03 am ]
Ive got 6
Author:  tchauvin [ Mon Sep 24, 2012 11:28 am ]
2011 prodrive, 420hrs...
1-bad reverse cylinder
1-bad power trim switch
1-broke muffler which is common with all motors.
Author:  mudslut [ Mon Sep 24, 2012 11:34 am ]
07 MB 27 got 180 hr and had a few bent push rods
Author:  woodysqueal23 [ Mon Sep 24, 2012 2:02 pm ]
2011 Gtr 103 hours. 2 cracked stock mufflers and 1 leaky case gasket
Author:  slingshot [ Mon Sep 24, 2012 4:21 pm ]
2010 27 mudbuddy mini 137 hours and two cracked base plates. POS IMHO.
Author:  bubba777 [ Mon Sep 24, 2012 4:32 pm ]
Author:  CootSlayerRMFT [ Mon Sep 24, 2012 5:11 pm ]
Author:  BlueShamu [ Mon Sep 24, 2012 5:44 pm ]
2012 PD 36 HP - 29 Hours.
Piece of debris on the carb's float valve at < 3 hours.
Loose cavitation plate screws (even with lok-tite) about every 9-10 hours.
Air Filter cover and knob backed out and lost around 21 hours. (had to replace)
Author:  duckzbuckz365 [ Mon Sep 24, 2012 6:41 pm ]
2012 MB 45 BD - 12 hrs
Author:  bubba777 [ Mon Sep 24, 2012 6:44 pm ]
Author:  riverratdm84 [ Mon Sep 24, 2012 7:05 pm ]
Dual mb 35s around 120 hrs one new muffler.
Author:  CootSlayerRMFT [ Mon Sep 24, 2012 7:17 pm ]
Author:  riverratdm84 [ Mon Sep 24, 2012 7:35 pm ]
Heres a couple pics.
Author:  STR8limits [ Mon Sep 24, 2012 7:57 pm ]
I used to run mud buddy but I got tired of all the electric problems switches, relays, Tilt and trim getting hung up.. water in my lower unit. It seemed like everytime i took it out I was working on it. it was a 35 hd sport with about 150 hrs.i switched to GD and I love it. it's so much more simple
Author:  take'emgator [ Mon Sep 24, 2012 9:35 pm ]
09' GTR just turned 178hrs TODAY
Author:  deltaduckmaster [ Tue Sep 25, 2012 5:48 am ]
Turned 190 on the 2012 5 month old dual.
Author:  Quack Stackin [ Tue Sep 25, 2012 5:59 am ]
2012 35 MB, 70 hours and two trim relays
Author:  skinnerton_outlaw [ Tue Sep 25, 2012 8:32 am ]
2011 GTR 35, 96 hrs. Replaced case gasket, cracked crank case, trim switch, and prop
Author:  bussterwyatt [ Wed Sep 26, 2012 3:58 pm ]
Author:  basin runner [ Fri Feb 01, 2013 10:15 pm ]
09 prodrive 36hp. 400hrs and goin strong!
Author:  T-Bubba [ Fri Feb 01, 2013 10:19 pm ]
2010 360hrs
Author:  take'emgator [ Fri Feb 01, 2013 11:24 pm ]
185 bought 4 years ago
Author:  Bayoublackhunter [ Fri Feb 01, 2013 11:46 pm ]
243hrs in 8 months or so
Author:  Podcast [ Sat Feb 02, 2013 12:35 am ]
06 PD 27. No repairs I'm aware of, just unnecessary upgrades.
Author:  tchauvin [ Sat Feb 02, 2013 8:23 am ]
2011 PD, Lill over 300hrs...
1 reverse switch went out, and 1 trim cylinder caused by Marshemellow exhaust, and clutch is shot..
Author:  scatters boy 316 [ Sat Feb 02, 2013 8:57 am ]
just under 800 hrs on my 2007(bought it used) but replaced all bearings and seals when i had the motor modded at a little over 670 hours and no complaints what so ever. replaced all the seals in the drive when i modded the motor also and keep it greased and have had no problems.
Author:  cmk07c [ Sat Feb 02, 2013 1:53 pm ]
2011 Go Devil 23 SD, 103 hours. Nothing other than changing oil, greasing and belt tightening.
Author:  CootSlayerRMFT [ Sat Feb 02, 2013 3:24 pm ]
'07 35 GDSD: 445 hours
Just took it to Go Devil this week for new prop, shaft, seals, and bushings. Aside from that, I exploded the U-joint in the lower unit at about 300 hours due to lack of greasing inside the covers. No other problems, and its running like a beast now!
Author:  cmk07c [ Tue Feb 05, 2013 8:45 am ]
Author:  barnes_53 [ Tue Feb 05, 2013 12:03 pm ]
Had an 09 35 GDSD with around 230 hours and the only thing I had to fix was the belt I snapped running stumps (it was my fault). Other than that routine maintenance (oil change, grease).
Have a 2012 MB with 50 hours (bought brand new Aug 27) and have had to do the following:
Take valve overs off and adjust lash
Replace pushrod that slipped out due to incorrect valve lash
Replace oil sensor wire and wrap with heat shrink tubing
Replace entire lower drive assembly due to cracked skeg (cracked all the way through until you can see daylight)
waiting on the next thing to add to the list LOL
Author:  brasso [ Tue Feb 05, 2013 12:14 pm ]
Author:  barnes_53 [ Tue Feb 05, 2013 4:21 pm ]
Because of my loyalty to my local dealer who is a friend of mine and knows that customers drive his business.
Author:  Captchaz [ Tue Feb 05, 2013 4:28 pm ]
Author:  barnes_53 [ Tue Feb 05, 2013 4:31 pm ]
Page 1 of 2 All times are UTC - 6 hours
