It is currently Tue Apr 28, 2026 8:51 am
Reply to topic  [ 11 posts ]
 Rear Nav Light
Post Rear Nav Light
I know it was on the old site but can someone please post a link to buy the short, folding, white navigation lights that people mount on top of their motors? I think I y'all had a few different versions. I'm tired of fighting my boat blind trying to get the light in the socket at 4:00 am. Thanks
Thu Feb 19, 2009 11:10 pm
Post Re: Rear Nav Light
Leave it in the socket. But here is a trick so it dont break off. Go ahead and cut the pole and then sleeve it with some rubber heater hose so it can flex any way it wants and not have a problem.
Fri Feb 20, 2009 9:11 am
Nav lights should come in 3 or 6 packs. I found em on clearance at Walmarks last night. Bought em up.
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Fri Feb 20, 2009 10:40 am
18x48 Charles Leonard / 36PD
Fri Feb 20, 2009 10:57 am
Buy a white LED strip light app 4"X1/2" and mount to breather cover on GTr
problem solved. Had mine for 2 years in trees and other stuff no problems
Fri Feb 20, 2009 11:09 am
This is the one I use and might be the one you're talking about....
http://www.fishmaster.com/products/navlight.htm
Josh
"Grace calls us to change and then gives us the power to pull it off!"
Max Lucado
Fri Feb 20, 2009 11:52 am
Fri Feb 20, 2009 1:14 pm
18' Weldcraft - 90HP
1654 GD 35GDSD Bone stock, including a rusty exhaust.
The only time I've rooted for the crimson tide, my gf was 3 days late.
FOREVER LSU
Fri Feb 20, 2009 2:54 pm
Fri Feb 20, 2009 5:47 pm
Running my on the top of my motor not the filter unit and it folds down low enough when not in use. I didn't use the base it came with and just drilled two holes and bolted down.
Josh
Max Lucado
Fri Feb 20, 2009 5:53 pm
had the post style and broke it 3 times in a month. I dont know how to do pictures but the one i got is from academy about 4" long 1/2" wide and 3/4" tall. its very bright and made of lexan? hard to break. be sure and put alittle caulk around screws if in saltwater or you will get rust around air cleaner, found out after the fact.
Fri Feb 20, 2009 6:59 pm
