It is currently Tue Apr 28, 2026 5:59 pm
Reply to topic  [ 18 posts ]
 Surface drive question.
New Member
Post Surface drive question.
I have a 1544 Alweld with a 23 HP GoDevil surface drive with a 2 blade prop. Is it worth $450 to upgrade to a 3 blade prop.
Wed Apr 01, 2009 6:45 am
Post Re: Surface drive question.
I don't think so. I could buy 2 props for my motor for that price.
Talk to Gigafowl. LOL
He could probably get you one for free. :lol:
Wed Apr 01, 2009 7:20 am
Yah im sure giggafowl can get you some kind of discount.... Hell im sure he even knows exactly how they do in mud..... I mean deep water...... :roll:
Wed Apr 01, 2009 10:51 am
I can tell you that the tree blade does take ALOT of the vibration out of these motors!! As of performance I really could not tell you the diffrence there.
Wed Apr 01, 2009 11:10 am
The 3 blade will help on the vibration, but no so much on the tiller torque.
1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh!
Willett Welding custom boat trailer
Wed Apr 01, 2009 5:00 pm
My 23 didnt have a problem with vibration, and once the skeg was bent right, it didnt have a tiller torque problem either.
The 3 blade isnt but about $25 more, but you gotta get a new shaft, and its advisable to change the gear ratio
Just your basic cracka ass cracka
1840 gator tail with 35GTR
15xx Bateau with 15 honda
Wed Apr 01, 2009 6:05 pm
Attakapas24
From what Bart Baker of GoDevil has told me - they do not reccommend
the 11x11 three blade on the 23 GoDevil....
First because they built the SD to be lighter than the 27 and 35, so the
shaft is a smaller diameter....
Second they felt that the 23 did not have enough torque to make the
three blade really work the way it does on the bigger motors....
If you PM me I will give you his phone number - or - call Coco himself...
Now - I have a 17x42 Weldbilt with 27 GDSD - I just swapped from
the 2 blade 12x12 to the three blade 11x11 - where no ratio change or
alterations are needed.... I made two trips into Miller and Mud lakes
with this new three blade and from my perspective there is no difference
in tiller feel whatsoever.... It runs a bit slower at WOT but has more
mid speed torque and comes out of the hole as fast as my buddy's
35 GDSD on a 18x48 GDSD hull....
Eat - Sleep - Hunt ! ! !
Wed Apr 01, 2009 6:30 pm
Wed Apr 01, 2009 6:54 pm
3 blade is an 11x12 and they changed the ratio on the 23's. 2007 model 23 can't turn it without changing the ratio.
Freedom It Wasn't Free!!!
It Was Won!!!
Enjoy It!!!
The more you try to teach a stupid person something the dumber you get!!!
Wed Apr 01, 2009 6:57 pm
Wed Apr 01, 2009 7:12 pm
3 blades have a 12 pitch already. Called and asked if I could add some pitch to it to bring it to a 12 and Dawn @GD said it already is. Just gonna have to add some more cup.
It Was Won!!!
Enjoy It!!!
Wed Apr 01, 2009 7:15 pm
LaBirdman,
My original post below was incorrect....
After talking again to Bart - it is a 11x12 just as you posted - and even
on the 35HP there is a 1.4 to 1 ratio reduction to the prop - with higher
ration reductions in the smaller motors - like the 27 and 23.... It is the
ratio reduction which gives the smaller motors enough torque to use the
3 blade GoDevil 11x12 prop properly.... Like the current 23 SD with the
3 blade factory installed....
Also there are different makers of 3 blade props that might also be seen
in the field as well....
***** My original post which was incorrect - below *****
From what Bart told me there is only one GoDevil 3 blade and it is 11x11...
No 12 pitch yet... Least that is what I understood, notice there is no
pitch marking on the prop, cause there is only one design...
Wed Apr 01, 2009 8:08 pm
im pretty sure bart told you wrong then. or if bart told you right, then Lance told me wrong!
Thu Apr 02, 2009 5:19 am
Yall go get your story straight and come back when you're ready. :lol:
1660 Rhino High-Side with center console
90/65 Mercury 2 stroke Outboard jet pump
Run shallow, run loud.
Thu Apr 02, 2009 6:10 am
LaBirdman and White1,
My original post above was incorrect....
After talking again to Bart - it is an 11x12 just as you posted - and even
in the field as well with a variety of pitches and sizes....
Thu Apr 02, 2009 10:21 am
27's got a 1.6 to 1 ratio and 23's have a 1.7 to 1 ratio.
It Was Won!!!
Enjoy It!!!
Thu Apr 02, 2009 12:04 pm
yea thats cheap for a three blade mud motor wheel
runnin that GTR35 with straight exaust and KN air filter on that 14 ft. skiff.
Thu Apr 02, 2009 12:12 pm
Thu Apr 02, 2009 7:15 pm
